Cuda Go-wing install #2617721
02/06/19 11:53 AM
02/06/19 11:53 AM
iowa
copchaser Offline OP
iowa
I'm installing a go-wing on a 70 Cuda. I need the measurements for where I need to drill the 4 holes. Does any buddy got them? Thanks.
Re: Cuda Go-wing install [Re: copchaser] #2618972
02/09/19 10:08 AM
02/09/19 10:08 AM
NW Ohio
6pkaar Offline
6pkaar  Offline
NW Ohio
Just looked at the online Year One catalog and they still show the hole measurements on page 567.
Re: Cuda Go-wing install [Re: 6pkaar] #2619109
02/09/19 04:30 PM
02/09/19 04:30 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Here's the YO info along with a factory print covering 70-1 Cuda and Challenger, and a pic of what your 70 Cuda trunk lid underside should look like, hope this helps?
Mike
Re: Cuda Go-wing install [Re: copchaser] #2619487
02/10/19 06:33 PM
02/10/19 06:33 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
mounting the under trunk brackets will be spot on for the 4 holes I would think
Re: Cuda Go-wing install [Re: copchaser] #2619560
02/10/19 10:28 PM
02/10/19 10:28 PM
iowa
iowa
Thank you!
Re: Cuda Go-wing install [Re: copchaser] #2619563
02/10/19 10:39 PM
02/10/19 10:39 PM
New Mexico
JMCFAN Offline
JMCFAN  Offline
New Mexico
Need to cut the trunk on my 70RR. Have the templates... what do folks use to make the cuts.... I am scared....lol
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: Cuda Go-wing install [Re: JMCFAN] #2619781
02/11/19 01:49 PM
02/11/19 01:49 PM
moparx Offline
moparx  Offline
i would trace the template out, then use a unibit [if there is room] to get close to the radius size of the corners.
then use a wizz wheel to connect the dots.
get close, then finish the cutout with a small flap wheel.
just my thoughts on how i would do this, i'm not an expert, so keep that in mind.
beer
Re: Cuda Go-wing install [Re: moparx] #2619789
02/11/19 02:04 PM
02/11/19 02:04 PM
New Mexico
JMCFAN Offline
JMCFAN  Offline
New Mexico
beer
Thanks! wizz wheel?
Re: Cuda Go-wing install [Re: JMCFAN] #2619828
02/11/19 03:14 PM
02/11/19 03:14 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Originally Posted By JMCFAN
wizz wheel?
Small air powered/electric cut off/dremel wheel...
Re: Cuda Go-wing install [Re: DAYCLONA] #2619837
02/11/19 03:28 PM
02/11/19 03:28 PM
New Mexico
JMCFAN Offline
JMCFAN  Offline
New Mexico
wizz wheel?
Thanks! Have one for dremel!
