'72 Demon, Stock Tank - Elec. Pump & Filter mounting? #2617908
02/06/19 05:04 PM
02/06/19 05:04 PM
Wisconsin
wkroncke17 Offline OP
Wisconsin
All,
About to mock up stock tank (w/sump)
Would like ideas and or pics of electric fuel pump and filter mounting under the back of the car.
"Thinking" about making an aluminum plate with shock mounted studs to the underside and mounting the pump and filter on that???
Thanks in advance!!
Wally.
Re: '72 Demon, Stock Tank - Elec. Pump & Filter mounting? [Re: wkroncke17] #2617994
02/06/19 09:10 PM
02/06/19 09:10 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Originally had mine on the inside face of the R/R frame rail, near the spring eye. Worked fine well into the 10s.
Changed that the 2nd time to rear body panel crossmember, near spare tire well, thinking that it'd be better to have the fuel forced into the pump, as the car leaves harder now.
1/2 aluminum hard line with -8 hoses in & out of pump and in engine compt. Using -6 from regulator to bowls.
368" footbrake Duster; some guys with big motors run larger systems.
Re: '72 Demon, Stock Tank - Elec. Pump & Filter mounting? [Re: wkroncke17] #2618066
02/07/19 12:25 AM
02/07/19 12:25 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Pump hides behind the bracket......B.G. 240 HR.
I wouldn't worry a ton about a vibration mount......you can use one , but it is sort of over kill I think.
Might quiet the pump some , but that is about it.
Re: '72 Demon, Stock Tank - Elec. Pump & Filter mounting? [Re: tubtar] #2618349
02/07/19 04:51 PM
02/07/19 04:51 PM
Wisconsin
Wisconsin
Thank you tubtar!
I was thinking of putting it up in front of the tank - is that not a good idea?
Car will be on the street also, so is it a good idea to hang down in back?
Re: '72 Demon, Stock Tank - Elec. Pump & Filter mounting? [Re: wkroncke17] #2618372
02/07/19 05:52 PM
02/07/19 05:52 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
When I put the pump on my Valiant I tried putting it in front since I used the stock pickup. I really couldn't find anywhere that wouldn't interfere with the shocks, exhausr or rear end. I ended up putting it under the back of the car mounted to the panel the bumper mounted to. It tucked up high enough you really couldn't see it, and it never got hit by anything.
My '68 has it on the frame rail over the right side of the rear end, but it is a ladder bar with no exhaust.
Re: '72 Demon, Stock Tank - Elec. Pump & Filter mounting? [Re: wkroncke17] #2618418
02/07/19 07:22 PM
02/07/19 07:22 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Originally Posted By wkroncke17
[/quote]
Thank you tubtar!
These pumps prefer to push the fuel , so the shorter distance they have to draw , the better they work
You get the surge from acceleration pushing fuel toward the pump so it will never starve as long as the pick up sees fuel.
A diaphragm style pump draws fuel better than these do , but I have yet to see one with a capacity anywhere near what I wanted.
It really doesn't hang down that far because I took a hole saw to the trunk floor.......the top of the pump and the wires are inside the trunk and if you stood it on the bumper , it still wouldn't hit the ground.
Re: '72 Demon, Stock Tank - Elec. Pump & Filter mounting? [Re: wkroncke17] #2618968
02/09/19 08:47 AM
02/09/19 08:47 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
E body but the principles the same. If you can, make the pump level with or lower than the pick up point.
Pump bracket is bolted to the rear rail, isolated with 1/4" rubber sheet.
Re: '72 Demon, Stock Tank - Elec. Pump & Filter mounting? [Re: wkroncke17] #2619122
02/09/19 05:47 PM
02/09/19 05:47 PM
s.e. MI
P
partsforsale Offline
P
s.e. MI
Maybe something like a RobbMC power surge would be easier?
robbmc powersurge
Re: '72 Demon, Stock Tank - Elec. Pump & Filter mounting? [Re: partsforsale] #2619157
02/09/19 07:24 PM
02/09/19 07:24 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
robbmc powersurge
Interesting.
Pricey , but interesting.
Re: '72 Demon, Stock Tank - Elec. Pump & Filter mounting? [Re: wkroncke17] #2619766
02/11/19 01:25 PM
02/11/19 01:25 PM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
I have to hide my pump, so I made a bracket that hangs down from the upper shock studs. Places the pump even with the bottom of the tank and between the tank and the rear end right next to the round bulge in the 8 3/4” housing. I use the original fuel sending unit. Also mounted up near the top of the bracket a canton filter housing.
best of 11.39 at 117 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
Re: '72 Demon, Stock Tank - Elec. Pump & Filter mounting? [Re: FurryStump] #2620211
02/12/19 11:35 AM
02/12/19 11:35 AM
Wisconsin
Wisconsin
I'd like to see a pic of that if possible??
I got my tank back - now.....Do I run braided line the whole way up to the front?
Re: '72 Demon, Stock Tank - Elec. Pump & Filter mounting? [Re: wkroncke17] #2620327
02/12/19 05:07 PM
02/12/19 05:07 PM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
You could but on a street car it's probably not ideal if you use the woven type, flying road debris would be more of a concern than hard line.
In any event, the pic below is on my Duster street car using a Hot Rod City Garage aluminum tank. I had them weld threaded bungs on for line clamps, worked out great. The flex hose connects to hard lines on the RR frame rail which goes through the trans cross member to the engine bay. Hose is Russell Twist Lok.
After a lot of hemming and hawing, I decided against using an electric pump because on an A body it's almost impossible to mount it so the pump inlet/outlet is below the lowest point of the tank. Take that for what it's worth though there are plenty of EFPs out there mounted other than as directed by the almighty Holley and working just fine for thousands of years.
'71 Duster
'17 Ram 1500
Re: '72 Demon, Stock Tank - Elec. Pump & Filter mounting? [Re: wkroncke17] #2620508
02/12/19 09:58 PM
02/12/19 09:58 PM
Cab_Burge Online work
Cab_Burge  Online Work
I wouldn't tsk
Are you going to run a good electric pump on the car? If so mount it back as far as possible and try to get the inlet fitting even with the bottom of your sump up wrench I mounted my Maganfuel 275 and 300 electric pumps(I ran one at a time) on the inside of the passenger side rear subframe and ran 1/2 aluminum line up to the front of the K frame so I could mount the fuel regulator in front of the carbs. so it had high pressure up to the regulator and lower pressure to the carbs.(six pack)
Re: '72 Demon, Stock Tank - Elec. Pump & Filter mounting? [Re: wkroncke17] #2620824
02/13/19 03:49 PM
02/13/19 03:49 PM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
I’ll try and get a picture tonight.
Re: '72 Demon, Stock Tank - Elec. Pump & Filter mounting? [Re: wkroncke17] #2621265
02/14/19 02:06 PM
02/14/19 02:06 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Use a Magna 500 with a filter and mount it anywhere back there and you'll be fine!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: '72 Demon, Stock Tank - Elec. Pump & Filter mounting? [Re: hemi-itis] #2621340
02/14/19 04:34 PM
02/14/19 04:34 PM
Wisconsin
Wisconsin
I have this pump.
I hope it will suffice?
Still working on which filter to use?
Re: '72 Demon, Stock Tank - Elec. Pump & Filter mounting? [Re: wkroncke17] #2621434
02/14/19 09:55 PM
02/14/19 09:55 PM
Blue Ridge, VA
Plumb Wired Offline
Plumb Wired  Offline
Blue Ridge, VA
You didn't mention the HP level of the application or the volume of fuel needed but Aeromotive has come out with a line of tanks with the pump mounted internally. https://www.aeromotiveinc.com/product/gen-ii-stealth-fuel-tank-70-76-dart-duster/ or https://www.aeromotiveinc.com/product/70-76-dartduster-340-stealth-fuel-tank/
RIP Monte Smith
aka: OutlawFish
'98 Bickel Dodge Dakota PST
Re: '72 Demon, Stock Tank - Elec. Pump & Filter mounting? [Re: wkroncke17] #2621516
02/15/19 01:43 AM
02/15/19 01:43 AM
hemi-itis Offline
hemi-itis  Offline
You can never have too much fuel pump.
Re: '72 Demon, Stock Tank - Elec. Pump & Filter mounting? [Re: wkroncke17] #2621563
02/15/19 09:35 AM
02/15/19 09:35 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
On my mid 10 sec Duster street car I had an Aeromotive hot rod pump mounted to the passenger side frame rail right in front of the rear tire, and I used a Holley return style regulator up front.
I used a rubber pad between the pump and frame rail, made a big difference with pump noise and vibration. The return style regulator made it run cooler and quieter. Black nylon braided line on the whole car, looked and worked great.
Now my new car, a 70 Challenger, has a custom stainless fuel tank with an internal elec fuel pump, super clean and easy setup.
