steering hitting pan, b body
#2618340
02/07/19 04:30 PM
02/07/19 04:30 PM
Posts: 294 indy
70moparmike
indy
i have a milodon pan for auto cross,for 69 gtx. centerlink rod hits the pan on full swing side to side. no quick steering arms. what have you done to resolve, clearance pan? pan already on the motor. thanks for any help
Re: steering hitting pan, b body
[Re: 70moparmike]
#2618506
02/07/19 11:50 PM
02/07/19 11:50 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
As the man said "Hammertime".
[Re: 70moparmike]
#2618661
02/08/19 02:25 PM
02/08/19 02:25 PM
Supercuda
About to go away
About to go away
up yours
I guess I made the mistake of assuming he'd done all the easy stuff first.
[Re: 70moparmike]
#2618806
02/08/19 07:01 PM
02/08/19 07:01 PM
Posts: 5,405 Pikes Peak Country
TC@HP2
Pikes Peak Country
If you put a 3/8" bolt in a 1/2" hole, you have slop. Allow enough slop, and even new mounts can have different clearance than the old mounts. There is also the possibility that the thickness of the new mounts is not as much as it should be, so they allow the whole things to sit lower in the frame than designed.
IIRC, pre '70 big blocks have a steel mount that bolts to the block, an isolator that bolts to the steel mount which then bolts to the pad on the k frame. You have variation in the mounts. You have variation in the location they bolt into the mount (not much, but some) and variation where they bolt into the pad (I believe this may be a slot, not a round hole, but its been a while since I've worked on one). That's four possible variation points, per side, for a simple bolt in engine mount.
Relay rod I assume is the center link. If the center link is hitting a corner of the pan with the engine lifted, your engine is not level or your linkage is not moving in a flat plane. There may be a difference in the assembly of the mounts from one side to the other. The engine may not be set into the mounting slots equally.
Alignment of the steering linkage itself could also be a factor. I have found numerous Mopars over the years that had shims behind the steering box where it bolts to the K. You can alter the plane the linkage operates in by shimming the box to move this plane up or down. There also is the possibility of idler arm and its bushings not duplicating factory position, or the bushing is worn/bad and allow unwanted motion, or its specific mounting location is just slightly off. Or, in the case of ultimate tolerance stack up, a little bit of everything above is off, just a hair, but add them all together and now something hits.
Personally, I'd much rather install a 1/4" shim into an motor mount or try moving some other pieces of the puzzle around to create the necessary clearance before I'd hammer on a $400 oil pan.
[Re: 70moparmike]
#2619208
02/09/19 10:03 PM
02/09/19 10:03 PM
TC@HP2
Pikes Peak Country
I realize the autocross pan is configured differently than a stock pan and the sump is much larger. It also has the corners cut at an angle to allow for movement of the steering linkage, but because of its size, requires everything to be assembled with more precision on location for it to all work well together. With a 50 year old car, this may mean shifting some things around, possibly even cutting and correcting things at the far end of tolerance that has been there since it was built.
Does the center link drag across the sump constantly or it it only hitting as the steering reaches full lock and it it only in one direction or both? Is it just the center link or is the idler or pitman also hitting the corner notch? Again this could mean your mounts allow the engine to sit too far to one side or the other if it is only one corner or one part that hits. Although, it could also be your overall engine location is too far back in the chassis. If it moves forward so the front of the pan is closer to the K frame, that may create the space necessary on the steering linkage side. to move without contact.
If this is the case, then the loosening of mounts and brackets, including the transmission, would be necessary and then the whole thing would need to be pulled forward. Washers or shims between the engine block mounting ears and the mounting bracket may produce enough space to eliminate the contact.
This is a case where the longer quick ratio arms would prevent pan interference with the steering by moving all the linkage rearwards, but if you have confirmed they won't work with your headers, this may not be an option. Since it all together, have you physically confirmed you do not have the space for the longer arms?
[Re: 70moparmike]
#2620256
02/12/19 01:55 PM
02/12/19 01:55 PM
Posts: 679 Los Osos, Ca
CKessel
Los Osos, Ca
I had TTI's on my 65 w/440 and had no issues until I put in the FF stage 3 box with a new standard length pittman arm to replace the old p/s box and arm. The new arm was a little different than the old one and hit the tube. Bumped the tube in. There are differences sometimes, even on oe replacement parts, between manufactures.
Carl Kessel
[Re: 70moparmike]
#2621239
02/14/19 01:10 PM
02/14/19 01:10 PM
Posts: 1,267 Netherlands
72Challenger
Netherlands
Guess what you mean is the idler arm is hitting the pan at full swingto the right?
[Re: 70moparmike]
#2621965
02/16/19 01:12 AM
02/16/19 01:12 AM
Supercuda
About to go away
About to go away
up yours
As I said, Hammer time or it will self clearance at the most inconvenient and expensive time.
