steering hitting pan, b body #2618340
02/07/19 04:30 PM
02/07/19 04:30 PM
indy
70moparmike Offline OP
indy
i have a milodon pan for auto cross,for 69 gtx. centerlink rod hits the pan on full swing side to side. no quick steering arms. what have you done to resolve, clearance pan? pan already on the motor. thanks for any help
Re: steering hitting pan, b body [Re: 70moparmike] #2618506
02/07/19 11:50 PM
02/07/19 11:50 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
As the man said "Hammertime".
Don't be the exception.
Re: steering hitting pan, b body [Re: 70moparmike] #2618569
02/08/19 08:29 AM
02/08/19 08:29 AM
indy
indy
hoping would not have too but i guess hammer down thanks
Re: steering hitting pan, b body [Re: 70moparmike] #2618611
02/08/19 12:40 PM
02/08/19 12:40 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Before taking a hammer to it, I'd recommend lifting the engine and playing with the engine mounts a bit. While there is not a lot of slop in the various bolts and brackets, there is some and it could add up enough to allow the engine to sit low enough to interfere. For that matter, you could consider shimming the isolators to lift the engine up slightly to provide the necessary clearance.
Re: steering hitting pan, b body [Re: 70moparmike] #2618638
02/08/19 01:51 PM
02/08/19 01:51 PM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
Bad mounts?
Carl Kessel
Re: steering hitting pan, b body [Re: 70moparmike] #2618661
02/08/19 02:25 PM
02/08/19 02:25 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I guess I made the mistake of assuming he'd done all the easy stuff first.
Re: steering hitting pan, b body [Re: 70moparmike] #2618665
02/08/19 02:39 PM
02/08/19 02:39 PM
AndyF Offline
AndyF  Offline
It shouldn't hit so I would suspect that your motor mounts are shot or have moved. See if you can lift the engine up and retighten everything. While you're under there inspect the rubber mounts and replace if necessary.
Re: steering hitting pan, b body [Re: 70moparmike] #2618716
02/08/19 04:22 PM
02/08/19 04:22 PM
indy
indy
new mounts, relay rod is hitting the kick put at the rear of the pan? tryed to lift still hits at the rear on the right side at full travel?
Re: steering hitting pan, b body [Re: 70moparmike] #2618806
02/08/19 07:01 PM
02/08/19 07:01 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
If you put a 3/8" bolt in a 1/2" hole, you have slop. Allow enough slop, and even new mounts can have different clearance than the old mounts. There is also the possibility that the thickness of the new mounts is not as much as it should be, so they allow the whole things to sit lower in the frame than designed.
IIRC, pre '70 big blocks have a steel mount that bolts to the block, an isolator that bolts to the steel mount which then bolts to the pad on the k frame. You have variation in the mounts. You have variation in the location they bolt into the mount (not much, but some) and variation where they bolt into the pad (I believe this may be a slot, not a round hole, but its been a while since I've worked on one). That's four possible variation points, per side, for a simple bolt in engine mount.
Relay rod I assume is the center link. If the center link is hitting a corner of the pan with the engine lifted, your engine is not level or your linkage is not moving in a flat plane. There may be a difference in the assembly of the mounts from one side to the other. The engine may not be set into the mounting slots equally.
Alignment of the steering linkage itself could also be a factor. I have found numerous Mopars over the years that had shims behind the steering box where it bolts to the K. You can alter the plane the linkage operates in by shimming the box to move this plane up or down. There also is the possibility of idler arm and its bushings not duplicating factory position, or the bushing is worn/bad and allow unwanted motion, or its specific mounting location is just slightly off. Or, in the case of ultimate tolerance stack up, a little bit of everything above is off, just a hair, but add them all together and now something hits.
Personally, I'd much rather install a 1/4" shim into an motor mount or try moving some other pieces of the puzzle around to create the necessary clearance before I'd hammer on a $400 oil pan.
Re: steering hitting pan, b body [Re: 70moparmike] #2618971
02/09/19 10:08 AM
02/09/19 10:08 AM
indy
indy
shimming engine up will not help the centerlink from rubbing the middle of the pan kick out? i don't have the number on the pan but it is for auto cross and the pan is not like stock. it is way wider and thicker where the rod rubs. i thought a few years back there wasn't a fix for this, just hoping by now someone had come up with something? i know the headers won't fir with the quick ratio arms? thanks for all the suggestions.
Re: steering hitting pan, b body [Re: 70moparmike] #2619208
02/09/19 10:03 PM
02/09/19 10:03 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
I realize the autocross pan is configured differently than a stock pan and the sump is much larger. It also has the corners cut at an angle to allow for movement of the steering linkage, but because of its size, requires everything to be assembled with more precision on location for it to all work well together. With a 50 year old car, this may mean shifting some things around, possibly even cutting and correcting things at the far end of tolerance that has been there since it was built.
Does the center link drag across the sump constantly or it it only hitting as the steering reaches full lock and it it only in one direction or both? Is it just the center link or is the idler or pitman also hitting the corner notch? Again this could mean your mounts allow the engine to sit too far to one side or the other if it is only one corner or one part that hits. Although, it could also be your overall engine location is too far back in the chassis. If it moves forward so the front of the pan is closer to the K frame, that may create the space necessary on the steering linkage side. to move without contact.
If this is the case, then the loosening of mounts and brackets, including the transmission, would be necessary and then the whole thing would need to be pulled forward. Washers or shims between the engine block mounting ears and the mounting bracket may produce enough space to eliminate the contact.
This is a case where the longer quick ratio arms would prevent pan interference with the steering by moving all the linkage rearwards, but if you have confirmed they won't work with your headers, this may not be an option. Since it all together, have you physically confirmed you do not have the space for the longer arms?
Re: steering hitting pan, b body [Re: 70moparmike] #2619453
02/10/19 05:29 PM
02/10/19 05:29 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
The instructions in my 70 Charger headers from TTI listed that the fast ratio arms would not fit. They DO fit with 3/4" of clearance. I have even switched K members and they both allowed the same clearance. I think TTI just covers their ass by stating this.
Re: steering hitting pan, b body [Re: 70moparmike] #2620256
02/12/19 01:55 PM
02/12/19 01:55 PM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
I had TTI's on my 65 w/440 and had no issues until I put in the FF stage 3 box with a new standard length pittman arm to replace the old p/s box and arm. The new arm was a little different than the old one and hit the tube. Bumped the tube in. There are differences sometimes, even on oe replacement parts, between manufactures.
Carl Kessel
Re: steering hitting pan, b body [Re: 70moparmike] #2621162
02/14/19 08:43 AM
02/14/19 08:43 AM
indy
indy
it only hits the pan on the right side at full travel to the right. no i haven't bolted the headers on because of the disclaimer on the tti header instructions? thought i would get this issue with the pan worked out first. thanks moparts
Re: steering hitting pan, b body [Re: 70moparmike] #2621239
02/14/19 01:10 PM
02/14/19 01:10 PM
Netherlands
72Challenger Offline
Netherlands
Guess what you mean is the idler arm is hitting the pan at full swingto the right?
Re: steering hitting pan, b body [Re: 70moparmike] #2621570
02/15/19 09:58 AM
02/15/19 09:58 AM
indy
indy
yes, that is what is going on.
Re: steering hitting pan, b body [Re: 70moparmike] #2621745
02/15/19 05:03 PM
02/15/19 05:03 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
These aftermarket idlers, pitmans, and lower ball joints all have different exterior configurations.
And I have some doubt they are 110% geometrically all identical.
The limit bump on the LBJ limits the movement/sweep of the idler. And how worn/smashed the lower control arm reciever for the bump will change the idler total sweep.
I’ve seen a big block car with a dent in one. I think I posted it here before.
Mine has a slight ding too.
Re: steering hitting pan, b body [Re: 70moparmike] #2621747
02/15/19 05:07 PM
02/15/19 05:07 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Re: steering hitting pan, b body [Re: 70moparmike] #2621965
02/16/19 01:12 AM
02/16/19 01:12 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
As I said, Hammer time or it will self clearance at the most inconvenient and expensive time.
Re: steering hitting pan, b body [Re: 70moparmike] #2622840
02/18/19 09:14 AM
02/18/19 09:14 AM
indy
indy
that is my pan story in a nutshell!
