simplest cheapest easiest trans to use in a 70 challenger #2616009
02/02/19 03:36 PM
02/02/19 03:36 PM
BC Canada
O
ogopogo Offline OP
ogopogo  Offline OP
O
BC Canada
what are my options for 6.4 truck engine and auto trans in a 70 challenger swap? we were thinking NAG1 but seems too costly and complicated at this point.Im assuming a plain old SB727 would be the easiest but would really like an OD gear.......A518 maybe? appreciate any advice thnx!!
Re: simplest cheapest easiest trans to use in a 70 challenger [Re: ogopogo] #2616021
02/02/19 04:16 PM
02/02/19 04:16 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
727 with a gear vendor would be your best bet for an overdrive without hacking on the car much. A 518 auto would be nice but it requires some tunnel work.
68 Barracuda Formula S 340
Re: simplest cheapest easiest trans to use in a 70 challenger [Re: Bad340fish] #2616022
02/02/19 04:26 PM
02/02/19 04:26 PM
BC Canada
O
ogopogo Offline OP
ogopogo  Offline OP
O
BC Canada
i am ok with small amount of tunnel work fyi...
Re: simplest cheapest easiest trans to use in a 70 challenger [Re: ogopogo] #2616089
02/02/19 06:50 PM
02/02/19 06:50 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
A 518 will fit an e-body without too much work as the crossmember is back further than a b-body( they need the t-bar crossmember modified). There are build threads if you google.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: simplest cheapest easiest trans to use in a 70 challenger [Re: ogopogo] #2633963
03/18/19 09:45 AM
03/18/19 09:45 AM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
518 will bolt right up =, minimal mods. call pro trans in lancaster ca.
Re: simplest cheapest easiest trans to use in a 70 challenger [Re: 70blackfish] #2634015
03/18/19 11:55 AM
03/18/19 11:55 AM
BC Canada
O
ogopogo Offline OP
ogopogo  Offline OP
O
BC Canada
we actually just picked up a 46rh from a 94 ram 2wd so thats our plan now (same as 518 right?) just need to learn about how to operate the od and converter lockup....
Re: simplest cheapest easiest trans to use in a 70 challenger [Re: ogopogo] #2634039
03/18/19 12:58 PM
03/18/19 12:58 PM
SoMd, USA
135sohc Offline
135sohc  Offline
SoMd, USA
The '518' is just the original designation for the 727 based OD transmission. There are a few good how-to's out there to make it work depending upon how automated or manually controlled you want to go.
Re: simplest cheapest easiest trans to use in a 70 challenger [Re: 70blackfish] #2634080
03/18/19 02:41 PM
03/18/19 02:41 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Pro Trans is finishing a move to Waco TX, look at Facebook for their new phone number.
The best in racing transmissions, I would assume the street transmissions would be first class as well.
Re: simplest cheapest easiest trans to use in a 70 challenger [Re: 340Cuda] #2635137
03/21/19 10:45 AM
03/21/19 10:45 AM
The Netherlands, OV
dickdale Offline
dickdale  Offline
The Netherlands, OV
A518 should be the easiest to install. There 46RH version can be used with 2 pressure switches and 2 timers.
