Re: simplest cheapest easiest trans to use in a 70 challenger
[Re: ogopogo]
#2616021
02/02/19 04:16 PM
02/02/19 04:16 PM
Posts: 8,021 Tulsa OK
Bad340fish
Tulsa OK
727 with a gear vendor would be your best bet for an overdrive without hacking on the car much. A 518 auto would be nice but it requires some tunnel work.
68 Barracuda Formula S 340
[Re: ogopogo]
#2616089
02/02/19 06:50 PM
02/02/19 06:50 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
A 518 will fit an e-body without too much work as the crossmember is back further than a b-body( they need the t-bar crossmember modified). There are build threads if you google.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: 70blackfish]
#2634080
03/18/19 02:41 PM
03/18/19 02:41 PM
Posts: 3,509 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
518 will bolt right up =, minimal mods. call pro trans in lancaster ca. Pro Trans is finishing a move to Waco TX, look at Facebook for their new phone number. The best in racing transmissions, I would assume the street transmissions would be first class as well.
