R&R 904 pump/ext housing bushings #2615835
02/02/19 01:45 AM
02/02/19 01:45 AM
RapidRobert Offline OP
What do I need to do this? chisel a notch in em to weaken it/cave it in a bit then work it out OR a flat round disc the dia of em & press it out OR? Can I freeze the new ones & drive em in easy without damage? Thank you for your time.
Re: R&R 904 pump/ext housing bushings [Re: RapidRobert] #2615840
02/02/19 01:53 AM
02/02/19 01:53 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Your flat round disc is also called a bushing driver. That's how to do it.
Re: R&R 904 pump/ext housing bushings [Re: RapidRobert] #2615845
02/02/19 02:09 AM
02/02/19 02:09 AM
Memphis,TN
J. Hammer Offline
J. Hammer  Offline
Memphis,TN
Take them to a trans guy and pay him to do it before you cause yourself more work?
Re: R&R 904 pump/ext housing bushings [Re: J. Hammer] #2615853
02/02/19 02:30 AM
02/02/19 02:30 AM
Yeah cuz I dont have a bushing driver.
Re: R&R 904 pump/ext housing bushings [Re: RapidRobert] #2615859
02/02/19 02:56 AM
02/02/19 02:56 AM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
I use an adjustable cam bearing driver with rubber boots for mine.
Re: R&R 904 pump/ext housing bushings [Re: RapidRobert] #2615871
02/02/19 04:48 AM
02/02/19 04:48 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Pay the shop or buy the driver. Check oreilys they loan tools.
Re: R&R 904 pump/ext housing bushings [Re: NANKET] #2615970
02/02/19 02:16 PM
02/02/19 02:16 PM
Oreilly's is a good thought & all be darned I DO have an adjustable cam bearing tool! thanks guys! EDIT any caveats on the install? freeze it/blue or green loctite or nothing?
Re: R&R 904 pump/ext housing bushings [Re: RapidRobert] #2615978
02/02/19 02:28 PM
02/02/19 02:28 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
Yo rR .... after the old bushing is out stick the ext housing in the oven at maybe 200 degrees and the new bushing should jsta slide in !
Re: R&R 904 pump/ext housing bushings [Re: dOoC] #2615989
02/02/19 02:42 PM
02/02/19 02:42 PM
Doc I'll do it
Re: R&R 904 pump/ext housing bushings [Re: RapidRobert] #2615990
02/02/19 02:48 PM
02/02/19 02:48 PM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
yO Rr .... how bad was that original bushing ? HONESTLY- in the many trans jobs I’ve done way back when -!i don’t think I ever replaced maybe LESS THAN 6 ext housing bushings ! That a rare part to fail - in my experience
Re: R&R 904 pump/ext housing bushings [Re: dOoC] #2615993
02/02/19 02:52 PM
02/02/19 02:52 PM
Well you know Doc I ain't actually got that far yet but the kit (from Cope) had em so I figured I might as well be proactive.
Re: R&R 904 pump/ext housing bushings [Re: RapidRobert] #2615997
02/02/19 02:58 PM
02/02/19 02:58 PM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
Rr.., well I’d CHECK if there is any slop in the bushing to slip spline - and IF within spec ....
I would suggest doing something more productive - like plowing through a sNoW dRiFt !! coffee
Re: R&R 904 pump/ext housing bushings [Re: RapidRobert] #2616001
02/02/19 03:01 PM
02/02/19 03:01 PM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
......ORE spending more time on Moparts !! laugh2
Re: R&R 904 pump/ext housing bushings [Re: RapidRobert] #2616002
02/02/19 03:05 PM
02/02/19 03:05 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Yes the rear bushing rarely fails. They don't need loctite.
Re: R&R 904 pump/ext housing bushings [Re: dOoC] #2616003
02/02/19 03:16 PM
02/02/19 03:16 PM
& with it going in the stock car, if it leaks out the back or front it ain't gonna hurt anything in a 30 minute race so what I could do is save em for when I do a DD & at that point in time get a kit WO the bushings. What I will do is take your advice & fit the yoke & go from there. EDIT & no loctite
Re: R&R 904 pump/ext housing bushings [Re: RapidRobert] #2616445
02/03/19 03:03 PM
02/03/19 03:03 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
You will have no issues if you have a cam bearing tool, tap right out and back in. I will warn you on the front bushing that after installing it try the fit on the converter, make sure it has a little clearance and no tight spots or it may destroy the converter snout. Almost never an issue but check it.
Re: R&R 904 pump/ext housing bushings [Re: 4406bbl] #2616470
02/03/19 04:06 PM
02/03/19 04:06 PM
for sure noted, thank you.
