R&R 904 pump/ext housing bushings
#2615835
02/02/19 01:45 AM
02/02/19 01:45 AM
RapidRobert
What do I need to do this? chisel a notch in em to weaken it/cave it in a bit then work it out OR a flat round disc the dia of em & press it out OR? Can I freeze the new ones & drive em in easy without damage? Thank you for your time.
Re: R&R 904 pump/ext housing bushings
[Re: J. Hammer]
#2615853
02/02/19 02:30 AM
02/02/19 02:30 AM
RapidRobert
Yeah cuz I dont have a bushing driver.
[Re: NANKET]
#2615970
02/02/19 02:16 PM
02/02/19 02:16 PM
RapidRobert
Oreilly's is a good thought & all be darned I DO have an adjustable cam bearing tool! thanks guys! EDIT any caveats on the install? freeze it/blue or green loctite or nothing?
[Re: BeEtLeJuIcE !]
#2615993
02/02/19 02:52 PM
02/02/19 02:52 PM
RapidRobert
Well you know Doc I ain't actually got that far yet but the kit (from Cope) had em so I figured I might as well be proactive.
[Re: BeEtLeJuIcE !]
#2616003
02/02/19 03:16 PM
02/02/19 03:16 PM
RapidRobert
& with it going in the stock car, if it leaks out the back or front it ain't gonna hurt anything in a 30 minute race so what I could do is save em for when I do a DD & at that point in time get a kit WO the bushings. What I will do is take your advice & fit the yoke & go from there. EDIT & no loctite
[Re: 4406bbl]
#2616470
02/03/19 04:06 PM
02/03/19 04:06 PM
RapidRobert
for sure noted, thank you.
