LX Shifter - can't get out of park #2615715
02/01/19 08:45 PM
02/01/19 08:45 PM
Calgary, Alberta Canada
a12rag Offline OP
a12rag  Offline OP
Guess this is a common problem with the 2005 and up automatic shifters . . . thanks to a very small plastic piece that breaks off ! The actual replacement part can be had, made out of aluminum instead of plastic (yay!!) . . . anyhow, had this happen to my 06 Magnum yesterday - luckily it was parked in the garage ! So I went to NAPA and got the part, and 1.5hr later car was moving again !! . . . here is youtube showing whats involved !
https://www.youtube.com/watch?v=7Cd6Ocitj3k
Easy fix, just takes time to get to the part !!
Anyhow, for those with an automatic LX platform car . . .something to keep in mind !!!
Stay warm out there !
Cheers
Mark
Re: LX Shifter - can't get out of park [Re: a12rag] #2615751
02/01/19 10:26 PM
02/01/19 10:26 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Known problem..
OE part made out of nylon and breaks easily, back in 2005 Chrysler had a soft recall for it. Now a replacement part machined out of aluminum, made by Dorman #924-706..
Just my $0.02... wink
Re: LX Shifter - can't get out of park [Re: Sinitro] #2615807
02/02/19 12:48 AM
02/02/19 12:48 AM
Slantytown
DUFFMAN Offline
Ask And Ye Shall Receive
DUFFMAN  Offline
Slantytown
Originally Posted By Sinitro
Known problem..
https://www.amazon.com/Dorman-924-706-Ch...=dorman+924-706
Not machined out of aluminum but cast from Zamak, otherwise known as "pot metal". The billet aluminum versions were made by Billet Technologies, were much more expensive, and have been discontinued.
The quality of the Dorman piece is fine. I have one installed in my 2007 Mugnum SRT8 and it works great.
No longer taking $h!t from anyone!
Re: LX Shifter - can't get out of park [Re: a12rag] #2615865
02/02/19 03:59 AM
02/02/19 03:59 AM
Chicago, Illinois
Devil Online penguin-006
Devil  Online Penguin-006
Chicago, Illinois
Something to look forward too on my 2009 Challenger with 200,000 miles on it.
Re: LX Shifter - can't get out of park [Re: a12rag] #2615881
02/02/19 08:14 AM
02/02/19 08:14 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
What's kinda funny is it's known a a "pink thingy". laugh2
Do a google search for dodge charger pink thingy and the issue and the replacement part is what comes up.
https://www.google.com/search?client=fir...i71.g20WI4XWwzA
Re: LX Shifter - can't get out of park [Re: a12rag] #2615900
02/02/19 11:07 AM
02/02/19 11:07 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
I work with plastics- Injection molding and its amazing the difference in quality between lets say a name brand nylon- Zytel (expensive) and all the off brand supposed equivalents.(less expensive)
Keep old mopars alive.
Re: LX Shifter - can't get out of park [Re: Devil] #2616012
02/02/19 03:46 PM
02/02/19 03:46 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Not applicable to '08 and later.
Re: LX Shifter - can't get out of park [Re: a12rag] #2616044
02/02/19 05:16 PM
02/02/19 05:16 PM
Midwestern Indiana
duster2 Offline
duster2  Offline
Midwestern Indiana
Would this apply to a 2007 Jeep Patriot , my grand-daughter has this problem ?? She has a floor mounted shifter.
Frank
Re: LX Shifter - can't get out of park [Re: a12rag] #2616098
02/02/19 07:07 PM
02/02/19 07:07 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Frank
https://www.youtube.com/watch?v=-tMzEJYqu4I
Re: LX Shifter - can't get out of park [Re: a12rag] #2616294
02/03/19 02:48 AM
02/03/19 02:48 AM
LA & L.A.
MoparPosterChild Offline
LA & L.A.
Been there done that with this situation. You can pop off the plastic over surrounding the shifter and use an ink pen to engage the button to get it out of park. I got the replacement part and installed it myself. Pretty easy but inconvenient.
2018 Dodge DEMON #18
1970 Plymouth Duster 406" Stroker
1969 Charger 500" Stroker
1964 Dodge Polara 426 GEN III HEMI
1970 Plymouth Cuda Hellcrate Project car
1974 Dodge Ramcharger Project car
2017 Chrysler Pacifica Limited
2017 Ram 3500
2012 Dodge Caravan R/T
1972 Charger Mopar 392 HEMI Stolen
2008 Challenger SRT-8 Gone
2010 Challenger SRT-8 Gone
2006 Charger SRT-8 Gone
2007 Charger R/T Gone
Re: LX Shifter - can't get out of park [Re: a12rag] #2616418
02/03/19 01:54 PM
02/03/19 01:54 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Very common failure. I am sure the LX forums are all over this. Happened to me with a 07 Magnum R/T. I don't know if the replacement part it better but no failure with it so far.
I think somebody actually makes a billet replacement for the part that fails.
Re: LX Shifter - can't get out of park [Re: a12rag] #2616511
02/03/19 05:41 PM
02/03/19 05:41 PM
a12rag Offline OP
a12rag  Offline OP
The Napa brand part that I got, is aluminum . . . the dorman part is also a metal part. Pretty sure that the spring won't have enough strength to break the metal versus the original plastic . . . here is the OE pink plastic piece - the white spot is where the little hook piece broke off - this holds the one end of the spring . . . no spring, no movement !! . . . hence replacing with metal version as upgrade !!
Gotta admit I was lucky to have happen while parked in the garage at home !! . . .
Re: LX Shifter - can't get out of park [Re: MoparPosterChild] #2616543
02/03/19 06:49 PM
02/03/19 06:49 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Yep, right in the owner's manual.
Re: LX Shifter - can't get out of park [Re: John_Kunkel] #2616641
02/03/19 10:55 PM
02/03/19 10:55 PM
a12rag Offline OP
a12rag  Offline OP
Thats only for a problem with the brake interlock . . . the "pen" solution, you have to remove the chrome trim piece around the shifter, then you can look down at the top in front of the shifter - see the cable for the shift interlock, and then put the pen down there and move the cable towards the drivers door. . . . but that is not a permanent fix . . .
https://www.youtube.com/watch?v=7HMirgS7tDs
