Question on spark plug boot protectors - 90 degree?
#2613293
01/28/19 12:14 AM
01/28/19 12:14 AM
Posts: 1,074 So Cal, USA
Fab64
So Cal, USA
Hi all, I'm looking at boot protectors on the Summit website, and am wondering what the significance of "90 degree" is? How are the 90-degree sleeves different from the others? My Firecore plug boots aren't 90-degrees, but they're not straight either (see pic below). I'm looking for something that will slide over my boots, and protect them from my headers. Thinking about buying these: Taylor 2418 A note says; "Designed for 90 degree spark plug boots or most pre-assembled wires". All opinions welcome, thanks! Roger
Re: Question on spark plug boot protectors - 90 degree?
[Re: Fab64]
#2613381
01/28/19 05:22 AM
01/28/19 05:22 AM
Posts: 43,190 Bend,OR USA
Cab_Burge
Hi all, I'm looking at boot protectors on the Summit website, and am wondering what the significance of "90 degree" is? How are the 90-degree sleeves different from the others? My Firecore plug boots aren't 90-degrees, but they're not straight either (see pic below). I'm looking for something that will slide over my boots, and protect them from my headers. Thinking about buying these: Taylor 2418 A note says; "Designed for 90 degree spark plug boots or most pre-assembled wires". All opinions welcome, thanks! Roger those sleeves will probably be flexable enough to go over the 45 degree boot in your picture I use a different brand, maybe they are Taylors but not colored, and they seem to help some
[Re: Fab64]
#2613400
01/28/19 09:33 AM
01/28/19 09:33 AM
Posts: 4,457 Washington
madscientist
Washington
You may be able to find something like what you've pictured in a ceramic boot. That's all I use when header clearance is an issue. They go on sale every now and then and can be had relatively reasonably, but they can also be expensive.
[Re: Fab64]
#2613410
01/28/19 10:18 AM
01/28/19 10:18 AM
Posts: 21,073 Niles , Ohio
therocks
Niles , Ohio
My son just got the ones that look like fabric from Summit.Ran them on his 62 with 2 1/8 headers for like 6 yesr and never had a problem.IIRC it came in a 4 foot roll and you cut to fit.have a piece on my starter wire near my headers and been on 10 years.Rocky
Chrysler Firepower
