manual VB with brake-swap ? #2612041
01/25/19 01:53 PM
01/25/19 01:53 PM
moparx Offline OP
moparx  Offline OP
what changes need to be made to the 727 to swap out a valve body with brake to one without a brake ? can the rear vent location still be used ?
as always, up and bow TIA.
beer
Re: manual VB with brake-swap ? [Re: moparx] #2612590
01/26/19 02:56 PM
01/26/19 02:56 PM
moparx Offline OP
moparx  Offline OP
anyone ? shruggy
beer
Re: manual VB with brake-swap ? [Re: moparx] #2612607
01/26/19 03:25 PM
01/26/19 03:25 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Nothing needs to change. Straight swap assuming not trying to go back to full automatic.
Re: manual VB with brake-swap ? [Re: moparx] #2612610
01/26/19 03:29 PM
01/26/19 03:29 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Different folks do different subtle things when a brake is used - springs in high gear, clearances, pressure - but I don't think any of it is so different that the trans would have to come apart and be changed. The small hole typically drilled in the high drum doesn't seem to cause an issue with high gear. Some guys have used a good valve body with a brake in it and never used it. So if you like the way it works, just unhook the wire and forget about it.
Griner built one that applied the rear band when the brake was on and released gradually after the brake was released. The intention was to have the band off by the 1-2 shift. So my only concern, if you change it out, would be what's going on with the rear band. Other than that, I don't know of any issues including the vent at the back of the case.
Re: manual VB with brake-swap ? [Re: TRENDZ] #2612612
01/26/19 03:36 PM
01/26/19 03:36 PM
moparx Offline OP
moparx  Offline OP
this swap is just intended as a learning curve while the engine is sorted to the chassis, then the brake valve body will be re-installed.
the governor has been removed and trans has been built for a brake, but this is the first brake transmission i have owned. just wanted to find out if this was possible to do, and i don't want to ruin the trans in the process.
thanks for responding ! up
beer
Re: manual VB with brake-swap ? [Re: moparx] #2612618
01/26/19 03:43 PM
01/26/19 03:43 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Not sure there is a real reason to pull the valve body if you intend to go back to the brake at some point. The brake doesn't have to be used. Again, my only concern would be the band. If it's LBA, then that would eliminate that issue.
Re: manual VB with brake-swap ? [Re: CMcAllister] #2612633
01/26/19 04:18 PM
01/26/19 04:18 PM
moparx Offline OP
moparx  Offline OP
good point. i don't know if the brake is LBA or not. i'm not a fan of no LBA valve bodies.
i guess i'll have to investigate further into this brake vb.
beer
Re: manual VB with brake-swap ? [Re: moparx] #2612642
01/26/19 04:44 PM
01/26/19 04:44 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Ask the people who built it or pay attention to whether it has engine braking in low gear or not. Or check pressure at the rear servo port in low gear.
Re: manual VB with brake-swap ? [Re: moparx] #2612647
01/26/19 04:56 PM
01/26/19 04:56 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
I found on my old car with a brake it was a dog when just foot braking it
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: manual VB with brake-swap ? [Re: CMcAllister] #2613477
01/28/19 01:21 PM
01/28/19 01:21 PM
moparx Offline OP
moparx  Offline OP
i was thinking that, but i'm not sure who the trans was built for.
here is the sticker on the case. do you, or anyone, know of these guys ?
beer
Re: manual VB with brake-swap ? [Re: moparx] #2613479
01/28/19 01:24 PM
01/28/19 01:24 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
If only you had thier phone number😅
Re: manual VB with brake-swap ? [Re: TRENDZ] #2613488
01/28/19 01:42 PM
01/28/19 01:42 PM
moparx Offline OP
moparx  Offline OP
hmmmm, imagine that ! "if only !" laugh2
beer
Re: manual VB with brake-swap ? [Re: moparx] #2613519
01/28/19 02:44 PM
01/28/19 02:44 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Racing family here is Division 1. Multiple cars, all first class.
Re: manual VB with brake-swap ? [Re: CMcAllister] #2613526
01/28/19 02:55 PM
01/28/19 02:55 PM
moparx Offline OP
moparx  Offline OP
Thank You ! i was told these guys were a good builder, but i haven't had time to dig into this transmission. my intentions were to call [i really did see the number ! laugh2] and ask them if they do anything to mark their product in any way for future reference, ie, internal parts used for a particular job number.
thanks again CM, for the confidence builder ! bow
as i stated before, this is my first experience with a brake, and i'm just taking my baby steps, so i need all the help i can get. please bare with me guys, because i'm sure to ask more DUMB questions about trans brakes in the future !
beer
