manual VB with brake-swap ?
#2612041
01/25/19 01:53 PM
01/25/19 01:53 PM
Posts: 19,464 north of coder
moparx
what changes need to be made to the 727 to swap out a valve body with brake to one without a brake ? can the rear vent location still be used ? as always, and TIA.
Re: manual VB with brake-swap ?
[Re: moparx]
#2612607
01/26/19 03:25 PM
01/26/19 03:25 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Nothing needs to change. Straight swap assuming not trying to go back to full automatic.
[Re: moparx]
#2612610
01/26/19 03:29 PM
01/26/19 03:29 PM
Posts: 11,608 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Different folks do different subtle things when a brake is used - springs in high gear, clearances, pressure - but I don't think any of it is so different that the trans would have to come apart and be changed. The small hole typically drilled in the high drum doesn't seem to cause an issue with high gear. Some guys have used a good valve body with a brake in it and never used it. So if you like the way it works, just unhook the wire and forget about it.
Griner built one that applied the rear band when the brake was on and released gradually after the brake was released. The intention was to have the band off by the 1-2 shift. So my only concern, if you change it out, would be what's going on with the rear band. Other than that, I don't know of any issues including the vent at the back of the case.
[Re: moparx]
#2612618
01/26/19 03:43 PM
01/26/19 03:43 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Not sure there is a real reason to pull the valve body if you intend to go back to the brake at some point. The brake doesn't have to be used. Again, my only concern would be the band. If it's LBA, then that would eliminate that issue.
[Re: moparx]
#2612642
01/26/19 04:44 PM
01/26/19 04:44 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Ask the people who built it or pay attention to whether it has engine braking in low gear or not. Or check pressure at the rear servo port in low gear.
[Re: moparx]
#2612647
01/26/19 04:56 PM
01/26/19 04:56 PM
Posts: 1,030 ohio
67mprfan
ohio
I found on my old car with a brake it was a dog when just foot braking it
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
[Re: CMcAllister]
#2613477
01/28/19 01:21 PM
01/28/19 01:21 PM
moparx
Ask the people who built it or pay attention to whether it has engine braking in low gear or not. Or check pressure at the rear servo port in low gear. i was thinking that, but i'm not sure who the trans was built for. here is the sticker on the case. do you, or anyone, know of these guys ?
[Re: moparx]
#2613479
01/28/19 01:24 PM
01/28/19 01:24 PM
TRENDZ
Milwaukee WI
If only you had thier phone number😅
[Re: moparx]
#2613519
01/28/19 02:44 PM
01/28/19 02:44 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Racing family here is Division 1. Multiple cars, all first class.
[Re: CMcAllister]
#2613526
01/28/19 02:55 PM
01/28/19 02:55 PM
moparx
Thank You ! i was told these guys were a good builder, but i haven't had time to dig into this transmission. my intentions were to call [i really did see the number ! ] and ask them if they do anything to mark their product in any way for future reference, ie, internal parts used for a particular job number. thanks again CM, for the confidence builder ! as i stated before, this is my first experience with a brake, and i'm just taking my baby steps, so i need all the help i can get. please bare with me guys, because i'm sure to ask more DUMB questions about trans brakes in the future !
