Question about K-frame-to-motor-mount bolts #2612437
01/26/19 04:32 AM
01/26/19 04:32 AM
So Cal, USA
Fab64 Offline OP
Fab64  Offline OP
So Cal, USA
Hi all,
The holes in the K-frame that the motor mounts bolt to are about 5/8" in diameter, whereas the bolts themselves are only about 3/8". This seems pretty sloppy to me - is there a bushing or something that's supposed to go in there? There was nothing in the holes when I pulled the motor 2-1/2 years ago. Thanks for any advice.
Roger
Re: Question about K-frame-to-motor-mount bolts [Re: Fab64] #2612442
01/26/19 04:57 AM
01/26/19 04:57 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Nothing of the sort. The mounts sit down on the pads of the K frame. Then the bolts go in to secure the mounts. Sometimes the bolts won't line up and you have to move/rock the engine slightly or move the trans tail left or right to get the bolts in and threads started. That why the holes are larger.
Re: Question about K-frame-to-motor-mount bolts [Re: NANKET] #2612464
01/26/19 10:28 AM
01/26/19 10:28 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
And the bolts are stout enough at 7/16".
Re: Question about K-frame-to-motor-mount bolts [Re: buildanother] #2612825
01/26/19 11:45 PM
01/26/19 11:45 PM
So Cal, USA
Fab64 Offline OP
Fab64  Offline OP
So Cal, USA
Thanks, guys, I wondered if it might be something like that. Thanks for confirming. up
Re: Question about K-frame-to-motor-mount bolts [Re: buildanother] #2612828
01/26/19 11:51 PM
01/26/19 11:51 PM
iagree scope Definitely not 3/8 diameter tsk
