tire eating dodge #2611725
01/24/19 06:42 PM
01/24/19 06:42 PM
Iowa
coronetville Offline OP
Iowa
my 1997 dodge dually 4x4 eats front tires, worst is drivers side after 20 some years told "nothing can be done" is there?
Re: tire eating dodge [Re: coronetville] #2611773
01/24/19 08:22 PM
01/24/19 08:22 PM
It needs to be aligned properly for the tires to last like they should, even if it includes having the front axle housing straightened.
Maybe you need to take it to a shop that CAN fix it work scope
Re: tire eating dodge [Re: Cab_Burge] #2611820
01/24/19 10:01 PM
01/24/19 10:01 PM
Central NY
GarageDodge Offline
GarageDodge  Offline
Central NY
Needs to go to a aligment shop that can do it correctly.Alot don't want to mess with rusted&frozen adjusters,they say nothing else can be done,if you want to spend the money it can be fixed.
Re: tire eating dodge [Re: coronetville] #2611904
01/25/19 02:25 AM
01/25/19 02:25 AM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
Happened to me on my '01 Ram 4X4 through a couple sets of tires. Now fixed. Long story short, find another alignment shop
Re: tire eating dodge [Re: coronetville] #2611967
01/25/19 11:00 AM
01/25/19 11:00 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Find a front end shop that doesn't sell tires, that is where the experts really seem to be.
68 Barracuda Formula S 340
Re: tire eating dodge [Re: coronetville] #2612206
01/25/19 07:09 PM
01/25/19 07:09 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
Isn't there a heavy duty track bar that's supposed to help with tire wear?
Re: tire eating dodge [Re: coronetville] #2612373
01/26/19 12:45 AM
01/26/19 12:45 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
4x4.... caster and toe adjusters only. Any camber adjustments requires “manipulating” front axle or using “offset” ball joints. Honestly I rarely find anyone who wants to spend the money as it can be a time consuming venture.
....and you can get it closer: example if the truck is used mainly for towing, perform align with weight added to simulate tongue weight.
Re: tire eating dodge [Re: J_BODY] #2612425
01/26/19 03:32 AM
01/26/19 03:32 AM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
I'm not an alignment guy, but here's the long story: I bought my '01 in 2006. It needed new tires, and also slightly pulled to the right. Had the alignment checked when the new tires were installed and they claimed it was good. Wore the right front outside edge slightly. Next set of tires, repeat previous scenario. I recently bought tires (new) off the internet and took them to a local shop for installation. A friend recommended this particular (small) shop, said it's the best alignment shop in town. Sure enough, it runs straight, no pull to the right, and it needed no new parts. We'll see how they wear, but I'm confident they'll be good.
Re: tire eating dodge [Re: coronetville] #2613908
01/29/19 09:15 AM
01/29/19 09:15 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Run high psi, especially with a diesel
I want my fair share
Re: tire eating dodge [Re: SomeCarGuy] #2616303
02/03/19 03:32 AM
02/03/19 03:32 AM
Iowa
Iowa
thanks i will look into to it the truck has been towing all of its life [64000]
