Dominator acc. pump cam question
#261234
03/21/09 09:28 PM
03/21/09 09:28 PM
Posts: 12,232 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I believe the acc. pump shots on my Dominator are too big. It doesn't look like my 30cc pump cams will work. Are there 50cc pump cam kits like there are 30cc pump cam kits? Has anyone else had this issue? Other than changing pump cams, what else can I do to lessen the shot? I need less total fuel, not a change in duration, like nozzles would do. 30cc pumps would probably do the trick, but the pump arms won't work on the Dominator. Any thoughts on this would be appreciated.
Master, again and still
Re: Dominator acc. pump cam question
[Re: Dodgem]
#261236
03/21/09 10:26 PM
03/21/09 10:26 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I think the question says that this isn't a nozzle question. But I am glad to hear that you like your .025s.
[Re: Dodgem]
#261238
03/22/09 09:12 PM
03/22/09 09:12 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
That's what I have...9375. And it had 35s. It just plain gets too much fuel off the line. I have found that Holley makes only 2 pump cams for this carb. The stock Yellow and a White. The White does not use all the fuel in the pump while the yellow one does. I intend to order a couple of the White cams tomorrow. They are over $13 each. We'll see how that works.
