Engine Run Stand #2612170
01/25/19 06:13 PM
01/25/19 06:13 PM
Louisiana
K
kzinge1 Offline OP
kzinge1  Offline OP
K
Louisiana
Just curious what you guys are using for engine run stands. Looking for something less than $500 that is halfway decent and will hold a 440. I have all gauges, radiator, ignition, etc. Just need something to break motors in before they go into the car. Any help is appreciated
Re: Engine Run Stand [Re: kzinge1] #2612178
01/25/19 06:32 PM
01/25/19 06:32 PM
there just was a thread on a cheapie (maybe HF iirc), not sure how complete it was but several had bought it & seemed to be OK with it for what it is.
Re: Engine Run Stand [Re: kzinge1] #2612184
01/25/19 06:40 PM
01/25/19 06:40 PM
md
mopars4ever Online content
mopars4ever  Online Content
md
Robert, you may be thinking of this one???? https://www.walmart.com/ip/Mobile-Engine-Testing-Station/51985964
I think it was a cheaper price then.
Re: Engine Run Stand [Re: RapidRobert] #2612186
01/25/19 06:41 PM
01/25/19 06:41 PM
Cochise Co, Az, From Detroit
moetown Offline
moetown  Offline
Could have been this larin brand for 339.00 from wally.
Re: Engine Run Stand [Re: kzinge1] #2612188
01/25/19 06:42 PM
01/25/19 06:42 PM
md
md
treed ya by one minute. lol
Re: Engine Run Stand [Re: kzinge1] #2612201
01/25/19 07:05 PM
01/25/19 07:05 PM
Louisiana
K
kzinge1 Offline OP
kzinge1  Offline OP
K
Louisiana
I did see the Wal Mart one, but was curious if anyone has used it. I like the price on it but wasn't sure if it would fit a 440 on it.
I also looked at this one from Summit Racing https://www.summitracing.com/parts/sum-918015
Anybody use that one?
Re: Engine Run Stand [Re: kzinge1] #2612205
01/25/19 07:08 PM
01/25/19 07:08 PM
S.E. Michigan
ZIPPY Online content
ZIPPY  Online Content
S.E. Michigan
I made mine out of 2x12s. Worked great, did everything I needed it to do. It's just a rectangle to set the engine on, similar to how crate engines are usually shipped. But if you need it to look impressive, it sure won't do that.
Rich H.
Esse Quam Videri
Re: Engine Run Stand [Re: kzinge1] #2612252
01/25/19 08:47 PM
01/25/19 08:47 PM
montana
BANDIT Offline
BANDIT  Offline
montana
I built the base out of leftover 2” by 3” frame rail and used old roll bar tubing for upright rad supports and front engine mounts. Used an old adjustable reliever hitch for rear mount, made it adjustable for length. Fronts are also adjustable. Used casters off of the toolbox that is in my trailer. Built it in one weekend, only had to by $25.00 worth of steel, had gauges, radiator, ignition, etc laying around. Has had dozens of engines run on it. If I can remember how to put pics on here I’ll see if I can post it.
64 Dodge Coronet 440. In progress
1998. Dodge Avenger. 8.35@165. 4400 DA
250” Neil and Parks Slip Joint. 7.36@183.
4600 DA
242" Mullis Dragster. 6.90@ 200mph
Re: Engine Run Stand [Re: kzinge1] #2612254
01/25/19 08:55 PM
01/25/19 08:55 PM
Louisiana
K
kzinge1 Offline OP
kzinge1  Offline OP
K
Louisiana
The "homemade" stand sounds like a good idea, especially with the price that some of these stands are going for. I may end up going that route. Pics would probably help if you get a chance to post them. Thanks for the comments
Re: Engine Run Stand [Re: kzinge1] #2612270
01/25/19 09:31 PM
01/25/19 09:31 PM
TN
1DGEMAN Offline
1DGEMAN  Offline
TN
I also built my own. I have run 511 inch engines down to 273's on it. I will look for my pics of it.
Real Men shift for themselves
Re: Engine Run Stand [Re: kzinge1] #2612273
01/25/19 09:34 PM
01/25/19 09:34 PM
New York
polyspheric Offline
polyspheric  Offline
New York
How to break in an engine on a stand: you can't.
Boffin Emeritus
Re: Engine Run Stand [Re: kzinge1] #2612289
01/25/19 09:53 PM
01/25/19 09:53 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I just use the K member sitting on a truck tire. Mount the radiator to a couple of vertical 2x4s. I have pre-run quite a few engines over the years like that. No problems.
Master, again and still
Re: Engine Run Stand [Re: polyspheric] #2612302
01/25/19 10:27 PM
01/25/19 10:27 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
You can break in cam/lifters on the stand, which is my primary consideration. That and insure there are no leaks before installing in the car. It's silly I know.
Re: Engine Run Stand [Re: kzinge1] #2612305
01/25/19 10:35 PM
01/25/19 10:35 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
I have the Summit one. Held my 500 with filled block very nice. Ran up with no problems at all. Tray holds battery and gas can. Mounted ignition, fuel pump and filter on lower support. Glad I got the gauge kit, too.
Re: Engine Run Stand [Re: kzinge1] #2612336
01/25/19 11:26 PM
01/25/19 11:26 PM
I borrow one that looks a lot like that one, it works fine up
Re: Engine Run Stand [Re: polyspheric] #2612353
01/25/19 11:57 PM
01/25/19 11:57 PM
I was wondering about that too, if it would put enough load on the rings by gunning it repeatedly but there'd be no trans load.
Re: Engine Run Stand [Re: polyspheric] #2612389
01/26/19 01:22 AM
01/26/19 01:22 AM
sgcuda Offline
sgcuda  Offline
I've never seen anyone ever fire up a new engine and immediately take it out on the road to load it. You warm it up, bleed the cooling system, check temp and oil pressure, check the timing and idle, listen for noises, check for leaks. Usually takes about an hour or so. So what's the difference if I run it on my stand? If I have to tear into anything, I don't have to worry about scratching the paint on the fenders.
Re: Engine Run Stand [Re: kzinge1] #2612394
01/26/19 01:43 AM
01/26/19 01:43 AM
CT
mrrandyj Offline
mrrandyj  Offline
CT
I don't have a lot of extra space, and a stand alone engine run stand takes up a lot of room to store. I made brackets to mount the engine on the legs of a cherry picker out of some scrap I had laying around. The brackets take up almost no room to store. I made up a panel with a couple switches, a Chrysler ecu, and a starter relay, and I had an extra set of gauges sitting around to monitor temperature and oil pressure. It works great.
Re: Engine Run Stand [Re: sgcuda] #2612418
01/26/19 03:10 AM
01/26/19 03:10 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I used to do that. Put the engine it , hook everything up, top off the fluids and fire it up. I lived in town so I drove out to the expressway , there was 3 mile stretch to the next exit. I would do 3 blast up to about 100 and down and take the exit back to the house. Then checked everything over , never had a leak . Changed the oil and was ready for the track.
Re: Engine Run Stand [Re: kzinge1] #2612422
01/26/19 03:16 AM
01/26/19 03:16 AM
Texas
mprhound Offline
mprhound  Offline
Texas
Do you go to the Pate swap meet in Ft Worth at the end of April? I am going to take a run stand to sell, also there is a vendor that builds and sells them for that price range
