low race car #261189
03/21/09 08:08 PM
03/21/09 08:08 PM
Iowa
coronetville Offline OP
Iowa
Before I build something that will or will not work, I thought I would ask first How did everybody get their very, very, low racecar in a enclosed trailer? I want to further add that tranny will also hit on front of the ramp[door] also
Re: low race car [Re: coronetville] #261190
03/21/09 08:17 PM
03/21/09 08:17 PM
Woodstock , Georgia
Mopar_racer_99 Offline
Woodstock , Georgia
We are having that problem and we bought an electric trailer jack to decrease the angle on the trailer door. John
8.72 @ 154.6 ,68 Charger 578ci 440-1s, 3000# w/drvr, 2150 den/alt NA
Re: low race car [Re: coronetville] #261191
03/21/09 08:18 PM
03/21/09 08:18 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
My dragster went in with either A) jacking up the nose of the trailer to make the ramp door paralel to the floor, and/or B) Ramp door extension ramps.
Re: low race car [Re: coronetville] #261192
03/21/09 08:23 PM
03/21/09 08:23 PM
MR_P_BODY Offline
MR_P_BODY  Offline
6'8" door and 6'8" extensions that hinge on the top of the
door and its still close
Re: low race car [Re: MR_P_BODY] #261193
03/21/09 08:24 PM
03/21/09 08:24 PM
Poulsbo, WA
ChrisJohnston669 Offline
Poulsbo, WA
electric jack helps and I also have 2 ramps off the back that fold down. My car sits low and it works perfect.
Re: low race car [Re: MR_P_BODY] #261194
03/21/09 08:56 PM
03/21/09 08:56 PM
Lost in Pooler, GA
Gumbydammit Offline
Gumbydammit  Offline
Lost in Pooler, GA
Check this site out. Pit Pals
I'm Gumby dammit!
Re: low race car [Re: Gumbydammit] #261195
03/21/09 09:59 PM
03/21/09 09:59 PM
Mobile Al
Dale Offline
Dale  Offline
Mobile Al
I helped a friend with a Trans Am that was real low and with the long Nose on it that thing was a real pain to load. Years later after he got rid of it we were talking about how much trouble it was and he said you know we should have loaded it backwards. Its worth a try.
Re: low race car [Re: Dale] #261196
03/21/09 10:09 PM
03/21/09 10:09 PM
MR_P_BODY Offline
MR_P_BODY  Offline
My trailer sits pretty high(home made) but one of the
things I did was put 4 5" long alum posts at the top
of the door then the rubber bumpers mount on the posts
then the extensions have a wll on each side(home made
also)... heres a pic
Post deleted by Defbob [Re: MR_P_BODY] #261197
03/22/09 12:29 AM
03/22/09 12:29 AM
Re: low race car #261198
03/22/09 12:34 AM
03/22/09 12:34 AM
Left Coast
BobR Offline
BobR  Offline
Left Coast
I jack the trailer up as high as it will go......I've still caught the headers couple times ....The Arrow is about as low as you can go...
We have to raise our trailer up as high as it will go to get our car on-with the front end removed. The Procharger touches the trailer floor.
Re: low race car [Re: coronetville] #261199
03/22/09 07:48 AM
03/22/09 07:48 AM
Byron, NY
W.I.N. Racing Offline
Byron, NY
Thats why I have to take the front clip off my truck. The chin hits first, also I have two risers ( 2X8's) that start at the end of the dovetail on the main floor, so the pan dosent catch at the break from angle/flat
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: low race car [Re: coronetville] #261200
03/22/09 11:25 AM
03/22/09 11:25 AM
Central TEXAS!!!!
sr4440 Online content
sr4440  Online Content
Central TEXAS!!!!
here’s what I use
http://www.buffaloespeedenterprises.com/320086.html
they are a bit long, but they work without a hassle. I got tried of playing the “jack the trailer up” game with my trailer.
Joe
Without Data, you’re just another guy with an opinion.
Re: low race car [Re: sr4440] #261201
03/22/09 01:00 PM
03/22/09 01:00 PM
Lehigh Acres, Florida
rickstershemi Offline
here’s what I use
Joe
Buddy of mine has the same setup for his dragster, works great....
I bought a 60" set of RACE RAMPS for mine that are incredable, they are a composite material and weigh less than 10# a piece. Similar to the pic.....
Rickster
