My car is a pig! #2611376
01/24/19 01:40 AM
01/24/19 01:40 AM
Texas
mprhound Offline OP
mprhound  Offline OP
Texas
I scaled my car today, was heavier than I thought! Challenger, It has a glass hood, glass front bumper aluminum brackets, no back seat. Does have a 10 point mild steel cage, Dana 60 and a Siamese mega block, full tank of gas. I was not in the car. But it was better front to back than I expected!
Re: My car is a pig! [Re: mprhound] #2611382
01/24/19 01:51 AM
01/24/19 01:51 AM
Alberta
Wookie316 Offline
Wookie316  Offline
Alberta
That is without you in it?
My 71 Charger is 3860 without me.
I only have a 6 point and full interior.
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
Re: My car is a pig! [Re: Wookie316] #2611422
01/24/19 03:07 AM
01/24/19 03:07 AM
Any thoughts on what items are coming in heavier than than they should be?
Re: My car is a pig! [Re: mprhound] #2611436
01/24/19 04:03 AM
01/24/19 04:03 AM
nor cal
8
8pack Offline
8pack  Offline
nor cal
I have no idea where the manufacturers got heir weight from but they all seem very low compared to actual weights. I almost had a stroke when I weighed my gremlin and it is going to be over 3200# with glass and no interior....
Re: My car is a pig! [Re: mprhound] #2611438
01/24/19 04:13 AM
01/24/19 04:13 AM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
This happens quite regularly on built street/strip cars, they get heavy quick! Cage, safety equipment, heavy block, better cooling system, heavy duty trans with an added cooler, shield and gear vendors unit. Fuel system is heavier than stock, electrical system is heavier than stock, it all adds up!
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: My car is a pig! [Re: mprhound] #2611445
01/24/19 05:21 AM
01/24/19 05:21 AM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
Thats not bad with a cage, dana and aftermarket bb. My brothers 72 Cuda with a bb is 3650 with him in it. I bet the dana, cage and bb added 250lbs to your build.
Ok
Re: My car is a pig! [Re: mprhound] #2611452
01/24/19 08:27 AM
01/24/19 08:27 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
As I remember my street Challenger (SB 4 speed) was right around 3600 w/o driver. The factory bumpers weigh nothing. Hood helps. The cage is probably at least 120#. A Mega block weighs around 75# more than a 440 block. You can always work on it. My 64 Belvedere comes in at 3130 w/o driver,full interior (-back seat), mega block, 2 batteries, Dana, all steel exc hood.
Doug
Re: My car is a pig! [Re: mprhound] #2611454
01/24/19 08:56 AM
01/24/19 08:56 AM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
My 68 RR is 3780 Lbs with driver. 383 4 speed,Dana 60 & 8 point molly cage.
Re: My car is a pig! [Re: MoparBilly] #2611491
01/24/19 11:32 AM
01/24/19 11:32 AM
Texas
mprhound Offline OP
mprhound  Offline OP
Texas
I forgot about the gear vendor, and trans cooler, electric fans, big fuel pump etc. it all adds up. I will start looking for places to remove weight, just started reading the thread on here lots of good info there.
Re: My car is a pig! [Re: mprhound] #2611507
01/24/19 12:25 PM
01/24/19 12:25 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
2130# empty smile
5.53 @ 125 1/8th on the launch control..more left in her!
Re: My car is a pig! [Re: Eric] #2611575
01/24/19 02:56 PM
01/24/19 02:56 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
My '73 Challenger w/ me on digi-scales was 3755 #s
- full OEM interior, except back seat
- 8-point rollbar
- OEM RB block
- glass T/A replica hood
- 8.75" diff
- only 1/4 tank of fuel when weighed
- driver probably 185 at the time, so car was about 3570
When it comes back out, it's going to be heavier, regardless
- Victor heads feel like 10 #s more each than Stage VIs
- swapped 8.75" for Strange S-60... 40+ #s?
- driver about 210 #s now
- and at 6 #s per gallon of fuel, an easy 70 #s for closer to a full tank
Add an est. 130 #s w/o driver and I'd expect 3700 #s for car -- assuming full tank -- and 3900+ w/ driver.
Nope, NOT light.
Re: My car is a pig! [Re: mprhound] #2611642
01/24/19 04:28 PM
01/24/19 04:28 PM
Nevada
merpar Offline
merpar  Offline
Nevada
I did mild steel chassis on a 70' challenger, rectangle frame rails, dana 60, iron low deck and 906 iron heads. Without me in it was 2450lbs.
Re: My car is a pig! [Re: mprhound] #2611713
01/24/19 06:06 PM
01/24/19 06:06 PM
an8sec70cuda Online content
an8sec70cuda  Online Content
My cuda was 3780 lbs w/ me (320 lbs) in it and NO fuel. Had just backed it off the chassis dyno and the fuel pump was sucking air.
This was before I added all the nitrous crap onto it.
'70 cuda, all steel except for the fiberglass hood, 10 point MS cage, manual steering and brakes, no heater box, FULL factory interior (front buckets and back seat, all door panels, etc.), all aluminum hemi, 727, Dana 60, etc.
FWIW...my all aluminum hemi weighed the same as the iron block/aluminum headed 440 it replaced.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: My car is a pig! [Re: merpar] #2611784
01/24/19 08:41 PM
01/24/19 08:41 PM
That car must of had a bunch of really thin sheet metal on it work
My current S/P (1970 Cuda) car is a all chrome moly tube chassis with coil over suspension front and rear, narrowed Dana 60 with 40 spline axles and spool with dual disc brake calipers on the rear with fibreglas doors, hood, rear deck lid and both bumpers with all Lexan windows except for the front windshield, it weighs right at 2490 Lbs. wet ready to race with out me in it using a 400 block with aluminum heads and no radiator shruggy
Re: My car is a pig! [Re: mprhound] #2611792
01/24/19 08:54 PM
01/24/19 08:54 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Street Car Problems!
68 Barracuda Formula S 340
Re: My car is a pig! [Re: mprhound] #2611949
01/25/19 08:20 AM
01/25/19 08:20 AM
Mo.
racerx Offline
racerx  Offline
Mo.
Last time I weigh-in mine was 3180.8 point, glass hood, glass front bumper up
Re: My car is a pig! [Re: mprhound] #2611977
01/25/19 11:40 AM
01/25/19 11:40 AM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
The 64 is a "hefty" 3970 lbs all steel with a full cage and interior! But it still runs 9.80's @ 140
Re: My car is a pig! [Re: Bad340fish] #2611987
01/25/19 12:02 PM
01/25/19 12:02 PM
BradH Offline
BradH  Offline
Indeed.
Re: My car is a pig! [Re: BradH] #2612035
01/25/19 01:41 PM
01/25/19 01:41 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
3430# with me in it. All steel except the hood. Still has stock front and rear seat, carpet, door panels, dash, and headliner.
69 GTX 68 Road Runner
Re: My car is a pig! [Re: mprhound] #2612049
01/25/19 02:11 PM
01/25/19 02:11 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
My 68 Charger 3860 without me, 4050 with me.
