Transmission Oil Cooler Hose #2611668
01/24/19 05:08 PM
01/24/19 05:08 PM
Sao Paulo, Brazil
dart_73_br Offline OP
Sao Paulo, Brazil
Hello folls,
Which diameter do you use on your transmission oil cooler hose?
Br,
1973 Brasilian Dart
E100, boosted 390"
Re: Transmission Oil Cooler Hose [Re: dart_73_br] #2611679
01/24/19 05:24 PM
01/24/19 05:24 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
I use -6AN braided hose.
Re: Transmission Oil Cooler Hose [Re: Sammy] #2611687
01/24/19 05:31 PM
01/24/19 05:31 PM
S.E. South Dakota !
bigdad Online content
Still Posting A Lot
bigdad  Online Content
Still Posting A Lot
S.E. South Dakota !
same here
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Transmission Oil Cooler Hose [Re: bigdad] #2611697
01/24/19 05:40 PM
01/24/19 05:40 PM
an8sec70cuda Offline
iagree You don't need the more expensive Teflon lined hose either.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Transmission Oil Cooler Hose [Re: dart_73_br] #2611705
01/24/19 05:47 PM
01/24/19 05:47 PM
5/16 oil lines,(hose) not engine coolant lines(hosetsk) or fuel hose either tsk
I use as much steel lines as I can, minimum lengths of hose twocents
Re: Transmission Oil Cooler Hose [Re: dart_73_br] #2611729
01/24/19 06:48 PM
01/24/19 06:48 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
-6 Teflon hose. Locate the cooler as close to the trans as possible.
Re: Transmission Oil Cooler Hose [Re: dart_73_br] #2611737
01/24/19 07:05 PM
01/24/19 07:05 PM
Sao Paulo, Brazil
Sao Paulo, Brazil
Ok, I thought it needs to be located in front of front bumper. Where do you guys install it? Any pictures?
Cheers
1973 Brasilian Dart
E100, boosted 390"
Re: Transmission Oil Cooler Hose [Re: dart_73_br] #2611748
01/24/19 07:29 PM
01/24/19 07:29 PM
In front of the radiator.
CHIP
Re: Transmission Oil Cooler Hose [Re: dart_73_br] #2611765
01/24/19 07:58 PM
01/24/19 07:58 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I've put them under the car for years. Integral mount on the crossmember, back where the mufflers used to hang, just depends on the application. Heatsink style or small cooler/fan combos. Clean, hose runs kept short, less crap and plumbing in an already busy area. Never had one that didn't keep up.
