Transmission Oil Cooler Hose
#2611668
01/24/19 05:08 PM
01/24/19 05:08 PM
Posts: 637 Sao Paulo, Brazil
dart_73_br
Sao Paulo, Brazil
Hello folls,
Which diameter do you use on your transmission oil cooler hose?
Br,
1973 Brasilian Dart E100, boosted 390"
Re: Transmission Oil Cooler Hose
[Re: bigdad]
#2611697
01/24/19 05:40 PM
01/24/19 05:40 PM
Posts: 13,492 Marion, South Carolina [><]
an8sec70cuda
You don't need the more expensive Teflon lined hose either.
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
[Re: dart_73_br]
#2611705
01/24/19 05:47 PM
01/24/19 05:47 PM
Posts: 43,719 Bend,OR USA
Cab_Burge
5/16 oil lines,(hose) not engine coolant lines(hose ) or fuel hose either I use as much steel lines as I can, minimum lengths of hose
[Re: dart_73_br]
#2611729
01/24/19 06:48 PM
01/24/19 06:48 PM
Posts: 12,289 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
-6 Teflon hose. Locate the cooler as close to the trans as possible.
[Re: dart_73_br]
#2611737
01/24/19 07:05 PM
01/24/19 07:05 PM
dart_73_br
Sao Paulo, Brazil
Ok, I thought it needs to be located in front of front bumper. Where do you guys install it? Any pictures?
Cheers
[Re: dart_73_br]
#2611748
01/24/19 07:29 PM
01/24/19 07:29 PM
an8sec70cuda
In front of the radiator.
[Re: dart_73_br]
#2611765
01/24/19 07:58 PM
01/24/19 07:58 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I've put them under the car for years. Integral mount on the crossmember, back where the mufflers used to hang, just depends on the application. Heatsink style or small cooler/fan combos. Clean, hose runs kept short, less crap and plumbing in an already busy area. Never had one that didn't keep up.
