Fast / 6 #2610927
01/23/19 11:09 AM
01/23/19 11:09 AM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Fast / 6 [Re: bigdad] #2610980
01/23/19 12:52 PM
01/23/19 12:52 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Pretty cool and impressive. Man, the first impression I had, was of the crank whipping around like a garden hose laying out in the sun!
Re: Fast / 6 [Re: bigdad] #2610985
01/23/19 01:06 PM
01/23/19 01:06 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Might stout incline there.
Re: Fast / 6 [Re: bigdad] #2610996
01/23/19 01:20 PM
01/23/19 01:20 PM
New York
polyspheric Offline
polyspheric  Offline
New York
That power level may very well have busted the block if it were an NA build. IIRC even 400 is dangerous.
One nice thing about primitive engines: with boost VE is far less important that modern stuff. As long as you can keep a gasket on it (and the crank in the block), 10 more psi makes up for any lack of port CFM. The ancient Studebaker V8 has produced some amazing results.
Boffin Emeritus
Re: Fast / 6 [Re: polyspheric] #2611010
01/23/19 01:35 PM
01/23/19 01:35 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Am I guessing we will soon be hearing:
"Is that got a slant in it? laugh2
Re: Fast / 6 [Re: jcc] #2611013
01/23/19 01:40 PM
01/23/19 01:40 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
Re: Fast / 6 [Re: bigdad] #2611021
01/23/19 01:52 PM
01/23/19 01:52 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Slantzilla
You need a turbo
Re: Fast / 6 [Re: bigdad] #2611087
01/23/19 03:21 PM
01/23/19 03:21 PM
AndyF Offline
AndyF  Offline
Evidently you can make a silk purse out of a pig's ear.
Re: Fast / 6 [Re: bigdad] #2611109
01/23/19 04:00 PM
01/23/19 04:00 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Mike boosted this one and made it an AWB!!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Fast / 6 [Re: FastmOp] #2611110
01/23/19 04:04 PM
01/23/19 04:04 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Originally Posted By FastmOp
Slantzilla
You need a turbo
I have thought about it. I would rather go Procharger though.
Will knocked a piston out at 1000 feet on that run or he would have run an 8.XX. He told me it spun the tires and hit the rev limiter in 2nd gear which he believes got the piston. He's been busy crewing on the Vixen car lately, but is waiting for his motor to come back from machine shop prison. Will is a good dude for sure. boogie
Believe it or not, we have very little crank or block trouble at any level. The crank in my junk is one of the later "lightweight" cast iron cranks and I have been spinning it 7000 with stock rods. I have a shortblock with the same crank and aluminum rods. hammer
