Winters shifter #2609961
01/21/19 05:05 PM
01/21/19 05:05 PM
Usa
10secchallenger Offline OP
Usa
Any one here have any experience running a winters shifter? I’d like to hear the good/ bad about them. Was looking to buy one, looks similar to my turbo action shifter.
Re: Winters shifter [Re: 10secchallenger] #2609968
01/21/19 05:24 PM
01/21/19 05:24 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
the best shifter I ever had was a Winters SideWinder.
Re: Winters shifter [Re: rt66jim] #2609989
01/21/19 06:20 PM
01/21/19 06:20 PM
tboomer Offline
tboomer  Offline
And I still have mine! wave
Re: Winters shifter [Re: 10secchallenger] #2609997
01/21/19 06:40 PM
01/21/19 06:40 PM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
Here we go again. Do a search. This has been fought out a few times already.
BTW...1975 called, they want their Winters Shifter back.
Re: Winters shifter [Re: 10secchallenger] #2610020
01/21/19 07:29 PM
01/21/19 07:29 PM
PA
Harry's Taxi 2 Offline
PA
I really like mine, I had them in 3 cars. I think the Winters/ Sidewinders and Turbo-Action use the same mechanism and cable setup.
I like using modern, dummy proof, Winter's 1975 technology, since I'm shifting a 1960's designed transmission attached to a 1958 designed engine....kinda like a rotary dial phone, never drops calls and haven't had a dead battery in one yet.
Maybe we should all update to the new gated Precision Performance ones.....wait, that's right, I just remembered I had a gated shifter, it came factory in my "1970" Cuda. They called it a Slap-stick then.
Ratchet shifters are alright, they do get a little confused if you ask them to make more than one gear change though.
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
Re: Winters shifter [Re: CMcAllister] #2610038
01/21/19 08:15 PM
01/21/19 08:15 PM
Usa
Usa
Thanks for the kind words...didn’t ask what year they were, the question is if anyone has used them.... guess your kinda slow....
Re: Winters shifter [Re: 10secchallenger] #2610104
01/21/19 10:16 PM
01/21/19 10:16 PM
Usa
Usa
Anyone know if the cable comes in from the front or the rear on the transmission? Also Can an air shifter be mounted on on this shifter?
Re: Winters shifter [Re: 10secchallenger] #2610117
01/21/19 10:28 PM
01/21/19 10:28 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I have a JVX which is a relabeled Winters, mine exits the shifter from the front and enters the transmission from the rear. IIRC there were two rear entry kits, straight in like mine and one that had a bell crank where the cable was perpendicular to the center line of the transmission and used the bell crank and a short rod.
Re: Winters shifter [Re: CMcAllister] #2610157
01/21/19 11:26 PM
01/21/19 11:26 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Purple shafts and pinion snubbers.....
Re: Winters shifter [Re: CMcAllister] #2610201
01/22/19 12:31 AM
01/22/19 12:31 AM
New Jersey
69Chrgr Offline
69Chrgr  Offline
New Jersey
The Winters shifter design is sold by Cheetah, Turbo action, ATI, and of course, Winters. If you go to an NHRA race, most Stockers and Super stockers use a variation of this shifter. Although there are others out there, what shifter is better?
Re: Winters shifter [Re: J_BODY] #2610210
01/22/19 12:44 AM
01/22/19 12:44 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Easy there!!! I'm still pushing buttons boogie
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Winters shifter [Re: 10secchallenger] #2610515
01/22/19 04:46 PM
01/22/19 04:46 PM
Fulton County, PA
Mr. Helpful
Mr. Helpful
Fulton County, PA
Pick one. PPP, Pro Stick/Quarter Stick, M&M. ATI only has the old Winters for GM 3 speeds and C6 left. Their main one is the new M&M piece.
I've used one, never owned one. Too big, bulky, heavy, clunky and outdated for me. I may be slow, but I've made it into the 21st Century.
As far as 3 speeds in class cars...
