Spiralock in oil pan #2609894
01/21/19 03:11 PM
01/21/19 03:11 PM
new york usa
P
pattyboy 572 Offline OP
P
new york usa
Has anyone ever experienced this before
3/4 of a spiralock was found in oil pan.
What are possible causes. I caught it in time just want it not to happen again. Ty
Re: Spiralock in oil pan [Re: pattyboy 572] #2609896
01/21/19 03:14 PM
01/21/19 03:14 PM
from (piston) pin or (hyd) lifter. EDIT I missed the spira lock so that elims the lifters
Re: Spiralock in oil pan [Re: pattyboy 572] #2609911
01/21/19 03:35 PM
01/21/19 03:35 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Possible causes?
It was in the pan from the previous freshening, or it broke this time around and ended up in the pan.
Sometimes they break....... stuff happens.
Re: Spiralock in oil pan [Re: fast68plymouth] #2609919
01/21/19 03:47 PM
01/21/19 03:47 PM
Originally Posted By fast68plymouth
Possible causes?
iagree
The motor is talking to you saying it is broken, time to find out where and why up
OP, you need to take the pistons out to find which one is broken and then figure out why it fail to make sure it doesn't fail any more of them scope
I've had pistons that didn't have enough end play on the spiral locks so they would seat completely in the machine grooves puke scope
Most piston makers want from .0010 to .0030 end play at room temps with no oil shruggy My thinking on this is that a lot more(.003+) clearance is better than a tiny bit to little, less than .0009 work
Re: Spiralock in oil pan [Re: pattyboy 572] #2609929
01/21/19 04:05 PM
01/21/19 04:05 PM
So. Burlington, Vt.
So. Burlington, Vt.
It’s possible........ but not all that likely that piece made it into the pan without “touching” a few other parts along the way.
Might be a few nicks or scratches that could use some attention.
Re: Spiralock in oil pan [Re: pattyboy 572] #2609998
01/21/19 06:43 PM
01/21/19 06:43 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Pull the pistons. See whats broken. Hope the cylinder wall survived. If that stuff all looks good, re-evaluate your washing procedure for a block that's being made ready for assembly.
Re: Spiralock in oil pan [Re: pattyboy 572] #2610062
01/21/19 09:17 PM
01/21/19 09:17 PM
New York
polyspheric Offline
polyspheric  Offline
New York
The open end of the pin (if that's what happened) will slide over and dig a trench in your cylinder wall faster than you think.
Got to come apart, the block is too $$$ to lose.
Boffin Emeritus
Re: Spiralock in oil pan [Re: polyspheric] #2610086
01/21/19 09:59 PM
01/21/19 09:59 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
iagree
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Spiralock in oil pan [Re: polyspheric] #2610090
01/21/19 10:02 PM
01/21/19 10:02 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
My initial thought too. It does seem like a lot of pistons today are machined for double locks. Maybe for this reason?
Re: Spiralock in oil pan [Re: pattyboy 572] #2610111
01/21/19 10:21 PM
01/21/19 10:21 PM
So. Burlington, Vt.
So. Burlington, Vt.
Many race pistons that use spiro-lox, use two on each side.
Not that it really matters at this point........ it should come apart anyway, especially if you don’t know if your pistons used singles or doubles per side.
Re: Spiralock in oil pan [Re: pattyboy 572] #2610136
01/21/19 11:06 PM
01/21/19 11:06 PM
New York
polyspheric Offline
polyspheric  Offline
New York
This is a reminder to closely inspect the lock type you get, and especially the depth, shape and finish of the groove. Not recently, but I've see grooves not deep enough (lock cannot expand fully), or not wide enough for both locks (one is on the edge), and "new" locks that were obviously different diameters in their relaxed state, or apparently had been installed and removed (spiraled, so that the ends were overlapping, but not quite touching).
Good shops will never do that? If they haven't had a bad one in 10 years, are they really going to examine 48 small areas (8 × 4 + 16) without billing you?
Old Harley mechanic's rule: if the lock ("L" shaped cross-section in those days) is at all distorted, or does not "SNAP" completely on to the pin groove, throw it away.
Any of these could be a $$ in the making.
Boffin Emeritus
Re: Spiralock in oil pan [Re: pattyboy 572] #2610149
01/21/19 11:19 PM
01/21/19 11:19 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Keep us posted on your findings!
Re: Spiralock in oil pan [Re: J_BODY] #2610203
01/22/19 12:33 AM
01/22/19 12:33 AM
Good info (I learned something today).
Re: Spiralock in oil pan [Re: pattyboy 572] #2610207
01/22/19 12:40 AM
01/22/19 12:40 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
You must have a heated garage to just find that now eek
Who do you use> work
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Spiralock in oil pan [Re: pattyboy 572] #2610227
01/22/19 01:17 AM
01/22/19 01:17 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
I know someone that this happened to recently, it was a stroker motor. I don't remember who's kit, but it only used 1 spirolok per side. Pin killed the bore.
Re: Spiralock in oil pan [Re: pattyboy 572] #2610247
01/22/19 02:10 AM
01/22/19 02:10 AM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
I've seen this more than once on Harleys in my shop.Worst case,you'll end up with two grooves in the radius of the bore. If you are lucky and the other part of the retainer is still in the pin bore,then I'd say good timing!
Re: Spiralock in oil pan [Re: GTX MATT] #2610289
01/22/19 05:23 AM
01/22/19 05:23 AM
Icon pistons now come with a single piece three layer spirolock, is that what you saw?
Re: Spiralock in oil pan [Re: Cab_Burge] #2610295
01/22/19 06:44 AM
01/22/19 06:44 AM
missouri,usa
cryplydog Offline
cryplydog  Offline
missouri,usa
Cab,I have Icons with those spirolocs getting ready to assemble. should I use 2 per side or something else.?
Re: Spiralock in oil pan [Re: cryplydog] #2610468
01/22/19 03:35 PM
01/22/19 03:35 PM
What I remember is only enough keepers to do one per side on each piston shruggy scope The pistons are machined so only their keepers will fit in those pistons scope
No spares whiney Be careful on installing them up
Re: Spiralock in oil pan [Re: Cab_Burge] #2610582
01/22/19 06:41 PM
01/22/19 06:41 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
i just installed ICONs a a stroker 496,they came with one triple wound SL per side,they went in nice,i cant see them coming out unless there was a gltch puttin them in.
