Re: Spiralock in oil pan
[Re: pattyboy 572]
#2609896
01/21/19 03:14 PM
01/21/19 03:14 PM
RapidRobert
from (piston) pin or (hyd) lifter. EDIT I missed the spira lock so that elims the lifters
[Re: pattyboy 572]
#2609911
01/21/19 03:35 PM
01/21/19 03:35 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Possible causes?
It was in the pan from the previous freshening, or it broke this time around and ended up in the pan.
Sometimes they break....... stuff happens.
[Re: fast68plymouth]
#2609919
01/21/19 03:47 PM
01/21/19 03:47 PM
Posts: 43,232 Bend,OR USA
Cab_Burge
Possible causes?
Sometimes they break....... stuff happens. The motor is talking to you saying it is broken, time to find out where and why OP, you need to take the pistons out to find which one is broken and then figure out why it fail to make sure it doesn't fail any more of them I've had pistons that didn't have enough end play on the spiral locks so they would seat completely in the machine grooves Most piston makers want from .0010 to .0030 end play at room temps with no oil My thinking on this is that a lot more(.003+) clearance is better than a tiny bit to little, less than .0009
[Re: pattyboy 572]
#2609929
01/21/19 04:05 PM
01/21/19 04:05 PM
fast68plymouth
So. Burlington, Vt.
It’s possible........ but not all that likely that piece made it into the pan without “touching” a few other parts along the way.
Might be a few nicks or scratches that could use some attention.
[Re: pattyboy 572]
#2609998
01/21/19 06:43 PM
01/21/19 06:43 PM
Posts: 11,621 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Pull the pistons. See whats broken. Hope the cylinder wall survived. If that stuff all looks good, re-evaluate your washing procedure for a block that's being made ready for assembly.
[Re: pattyboy 572]
#2610062
01/21/19 09:17 PM
01/21/19 09:17 PM
Posts: 4,209 New York
polyspheric
New York
The open end of the pin (if that's what happened) will slide over and dig a trench in your cylinder wall faster than you think. Got to come apart, the block is too $$$ to lose.
Boffin Emeritus
[Re: polyspheric]
#2610086
01/21/19 09:59 PM
01/21/19 09:59 PM
Posts: 2,115 Byron, NY
W.I.N. Racing
Byron, NY
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: polyspheric]
#2610090
01/21/19 10:02 PM
01/21/19 10:02 PM
Posts: 4,318 Prospect, PA
BSB67
Prospect, PA
The open end of the pin (if that's what happened) will slide over and dig a trench in your cylinder wall faster than you think. Got to come apart, the block is too $$$ to lose. My initial thought too. It does seem like a lot of pistons today are machined for double locks. Maybe for this reason?
[Re: pattyboy 572]
#2610111
01/21/19 10:21 PM
01/21/19 10:21 PM
fast68plymouth
So. Burlington, Vt.
Many race pistons that use spiro-lox, use two on each side.
Not that it really matters at this point........ it should come apart anyway, especially if you don’t know if your pistons used singles or doubles per side.
[Re: pattyboy 572]
#2610136
01/21/19 11:06 PM
01/21/19 11:06 PM
polyspheric
New York
This is a reminder to closely inspect the lock type you get, and especially the depth, shape and finish of the groove. Not recently, but I've see grooves not deep enough (lock cannot expand fully), or not wide enough for both locks (one is on the edge), and "new" locks that were obviously different diameters in their relaxed state, or apparently had been installed and removed (spiraled, so that the ends were overlapping, but not quite touching).
Good shops will never do that? If they haven't had a bad one in 10 years, are they really going to examine 48 small areas (8 × 4 + 16) without billing you?
Old Harley mechanic's rule: if the lock ("L" shaped cross-section in those days) is at all distorted, or does not "SNAP" completely on to the pin groove, throw it away.
Any of these could be a $$ in the making.
Boffin Emeritus
[Re: J_BODY]
#2610203
01/22/19 12:33 AM
01/22/19 12:33 AM
RapidRobert
Good info (I learned something today).
[Re: pattyboy 572]
#2610227
01/22/19 01:17 AM
01/22/19 01:17 AM
Posts: 5,163 CT
GTX MATT
CT
I know someone that this happened to recently, it was a stroker motor. I don't remember who's kit, but it only used 1 spirolok per side. Pin killed the bore.
[Re: GTX MATT]
#2610289
01/22/19 05:23 AM
01/22/19 05:23 AM
Cab_Burge
Icon pistons now come with a single piece three layer spirolock, is that what you saw?
[Re: Cab_Burge]
#2610295
01/22/19 06:44 AM
01/22/19 06:44 AM
Posts: 47 missouri,usa
cryplydog
missouri,usa
Icon pistons now come with a single piece three layer spirolock, is that what you saw? Cab,I have Icons with those spirolocs getting ready to assemble. should I use 2 per side or something else.?
[Re: cryplydog]
#2610468
01/22/19 03:35 PM
01/22/19 03:35 PM
Cab_Burge
What I remember is only enough keepers to do one per side on each piston The pistons are machined so only their keepers will fit in those pistons No spares Be careful on installing them
