70 A-Body 4-Spd Reverse Lockout Linkage ID/Confirmation #2609081
01/19/19 06:35 PM
01/19/19 06:35 PM
MD
floyd Offline OP
floyd  Offline OP
MD
I think I have some reverse lockout components for 70 A-body. Any experts here able to confirm? I didn't find much online. Brewer's lists one of the linkage rods, but doesn't show the pivot assembly.
Not sure about that small rod in the second pic. Could be unrelated.
Thanks!
Re: 70 A-Body 4-Spd Reverse Lockout Linkage ID/Confirmation [Re: floyd] #2609089
01/19/19 07:03 PM
01/19/19 07:03 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Reverse lockout would be for a 3 or 4-speed manual with floor shift.
Yours looks like it may be for an automatic - http://www.hamtramck-historical.com/images/serviceHighlights/70%20sh%20261.jpg
Re: 70 A-Body 4-Spd Reverse Lockout Linkage ID/Confirmation [Re: Alaskan_TA] #2609126
01/19/19 09:06 PM
01/19/19 09:06 PM
MD
floyd Offline OP
floyd  Offline OP
MD
Thanks Barry. Do you have a diagram of the manual trans set up? I am wondering if it uses the same torque shaft.
Re: 70 A-Body 4-Spd Reverse Lockout Linkage ID/Confirmation [Re: floyd] #2609132
01/19/19 09:28 PM
01/19/19 09:28 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
I have a couple photos of the one in my 1970 3-speed stick shift 318 car & it different than yours.
It is not easy to get a good photo of one in the car though......
Re: 70 A-Body 4-Spd Reverse Lockout Linkage ID/Confirmation [Re: floyd] #2609134
01/19/19 09:30 PM
01/19/19 09:30 PM
St Louis, MO 63026
convx4 Offline
convx4  Offline
St Louis, MO 63026
I believe there are three 1970 A-body linkages.
The are:
4-speed/3-speed
Auto-floor shift
Auto-column shift
Should be the same for B,C and E body's.
Re: 70 A-Body 4-Spd Reverse Lockout Linkage ID/Confirmation [Re: floyd] #2609324
01/20/19 02:23 PM
01/20/19 02:23 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I’ve dealt with b and e manual trans lockouts and all of them have an adjustment in the torque shaft. Your does not, so it looks to me to be the auto lockout.
Re: 70 A-Body 4-Spd Reverse Lockout Linkage ID/Confirmation [Re: convx4] #2609912
01/21/19 03:39 PM
01/21/19 03:39 PM
cheshire, ct
davesmopars Offline
davesmopars  Offline
cheshire, ct
The are:
4-speed/3-speed
Auto-floor shift
Auto-column shift
There is three different ones for a body column lock out
auto
4 speed
3 speed
they are all different
Keeper of the 440 M code Cuda registry
mcodecuda@yahoo.com
Re: 70 A-Body 4-Spd Reverse Lockout Linkage ID/Confirmation [Re: davesmopars] #2609918
01/21/19 03:47 PM
01/21/19 03:47 PM
North Carolina USA
smuggler Offline
smuggler  Offline
North Carolina USA
Here's a picture of the correct 1970 A body 4-speed interlock. It's off my 1970 Plymouth 340 Duster. Very difficult to find em--trust me!
Hope it helps.
Re: 70 A-Body 4-Spd Reverse Lockout Linkage ID/Confirmation [Re: smuggler] #2609921
01/21/19 03:51 PM
01/21/19 03:51 PM
cheshire, ct
davesmopars Offline
davesmopars  Offline
cheshire, ct
Hope it helps.
this is correct
mcodecuda@yahoo.com
Re: 70 A-Body 4-Spd Reverse Lockout Linkage ID/Confirmation [Re: davesmopars] #2609981
01/21/19 05:54 PM
01/21/19 05:54 PM
MD
floyd Offline OP
floyd  Offline OP
MD
Thanks for the pics Smuggler. I need to dig a little more to see if I can come up with either linkage rod. Any chance you can post some close up pics and measurements?
The lower rod shown on Brewer’s site looks a bit different.
http://www.brewersperformance.com/proddetail.php?prod=IR617
Re: 70 A-Body 4-Spd Reverse Lockout Linkage ID/Confirmation [Re: floyd] #2610022
01/21/19 07:34 PM
01/21/19 07:34 PM
cheshire, ct
davesmopars Offline
davesmopars  Offline
cheshire, ct
Yes the Brewers rod is different but I think it will work. I will ask my buddy he bought one from them.
mcodecuda@yahoo.com
Re: 70 A-Body 4-Spd Reverse Lockout Linkage ID/Confirmation [Re: davesmopars] #2610711
01/22/19 10:00 PM
01/22/19 10:00 PM
North Carolina USA
smuggler Offline
smuggler  Offline
North Carolina USA
Unfortunately, I dont have a shot of the column rod but I will try to take one and post when I can. Here is a shot of the reverse rod as installed in the car.
Re: 70 A-Body 4-Spd Reverse Lockout Linkage ID/Confirmation [Re: smuggler] #2610728
01/22/19 10:38 PM
01/22/19 10:38 PM
North Carolina USA
smuggler Offline
smuggler  Offline
North Carolina USA
2 pics of the adjustment rod up to the column tab (Sorry, tuff to shoot in the car).
Re: 70 A-Body 4-Spd Reverse Lockout Linkage ID/Confirmation [Re: floyd] #2625808
02/25/19 12:33 PM
02/25/19 12:33 PM
MD
floyd Offline OP
floyd  Offline OP
MD
Thanks Smuggler!. Based on your pics and Barry’s scan of the FSM, it looks to me like I have parts of a column shift auto lock out. Understanding that were three different setups (manual trans, auto-column, and auto-console) is it likely that the torque shaft was common to all three types and only the upper and lower rods were different?
Also, any input on WIW? I can’t find any past sales online.
Re: 70 A-Body 4-Spd Reverse Lockout Linkage ID/Confirmation [Re: floyd] #2625903
02/25/19 04:05 PM
02/25/19 04:05 PM
cheshire, ct
davesmopars Offline
davesmopars  Offline
cheshire, ct
No the torque rod is different also
mcodecuda@yahoo.com
Re: 70 A-Body 4-Spd Reverse Lockout Linkage ID/Confirmation [Re: davesmopars] #2625964
02/25/19 06:01 PM
02/25/19 06:01 PM
MD
floyd Offline OP
floyd  Offline OP
MD
So there are three different torque shafts? I’m not seeing much difference between the one I have and the pics Smuggler posted. Anyone have the part numbers?
Re: 70 A-Body 4-Spd Reverse Lockout Linkage ID/Confirmation [Re: floyd] #2625989
02/25/19 06:29 PM
02/25/19 06:29 PM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
1970 Parts Catalog (May '70 revision)
19-48-45 A-BODIES
shaft, gearshift torque
2781 425 - w/a904 auto trans col shift
2800 939 - w/a727 auto trans col shift
shaft, gearshift lock torque
3467 612 - w/4 speed man trans floor shift
shaft, gearshift control torque
3467 064 - w/auto trans floor shift
shaft, gearshift col lock torque
2781 425 - w/a904 auto trans floor shift
2800 939 - w/a727 auto trans floor shift
Re: 70 A-Body 4-Spd Reverse Lockout Linkage ID/Confirmation [Re: 6bblgt] #2626001
02/25/19 06:58 PM
02/25/19 06:58 PM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
this looks the same as Brewer's scope
