68 Dart Grill center divider question. #2609107
01/19/19 07:52 PM
01/19/19 07:52 PM
Connecticut
jeff968 Offline OP
jeff968  Offline OP
Connecticut
I'm told that not all 68 Darts have the center divider piece. True? Is there any logic behind which cars they are seen on? Did they only use them during certain production months? Thanks!
1970 Dodge Challenger T/A
Re: 68 Dart Grill center divider question. [Re: jeff968] #2609116
01/19/19 08:29 PM
01/19/19 08:29 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Re: 68 Dart Grill center divider question. [Re: jeff968] #2609695
01/21/19 01:15 AM
01/21/19 01:15 AM
Clinton, NJ
N
njmopar Offline
njmopar  Offline
N
Clinton, NJ
I decided against the nose piece, for now. I am enjoying the look right now. I need to do some hood aligning to get things right. For some reason the NOS fenders are different slightly at the headlight bezels. I dont get it... Still got a ways to go, but in the home stretch.
If that is your car in the photo, I see you dont have the blackout behind the grille. If you want some detailed photos of my car as I tore it apart, it has some great detail. I duplicated as close as possible on mine. I also can show the harness routing, as the parking light connectors should protrude into the engine bay through the small holes in the rad support.
Re: 68 Dart Grill center divider question. [Re: jeff968] #2609926
01/21/19 04:01 PM
01/21/19 04:01 PM
cheshire, ct
davesmopars Offline
davesmopars  Offline
cheshire, ct
I believe early production GTS car hard them. But someone else might know for sure.
Keeper of the 440 M code Cuda registry
mcodecuda@yahoo.com
