I decided against the nose piece, for now. I am enjoying the look right now. I need to do some hood aligning to get things right. For some reason the NOS fenders are different slightly at the headlight bezels. I dont get it... Still got a ways to go, but in the home stretch.
If that is your car in the photo, I see you dont have the blackout behind the grille. If you want some detailed photos of my car as I tore it apart, it has some great detail. I duplicated as close as possible on mine. I also can show the harness routing, as the parking light connectors should protrude into the engine bay through the small holes in the rad support.
