rear disc brake / prop valve question conversion #2608448
01/18/19 04:46 AM
01/18/19 04:46 AM
midwest
superchuck Offline OP
On thin ice
On thin ice
midwest
My car is disc/ drum and I converting the rear to disc. Can I use the existing prop valve or remove it and install an adjustable one? Thanks
Re: rear disc brake / prop valve question conversion [Re: superchuck] #2608463
01/18/19 06:41 AM
01/18/19 06:41 AM
Norway
cudaerik Offline
cudaerik  Offline
Norway
You do not need a prop. valve with disc brakes in all four corners, all you need is a distribution block.
1970 Plymouth Cuda, 512cid on 230 400 block, 5 speed manual.(TKO 600)
1970 Dodge Charger 500, 446cid, 5speed manual.(TKO 600)
1969 Plymouth Roadrunner, 383cid, 5speed manual (Tremec TKX)
Re: rear disc brake / prop valve question conversion [Re: cudaerik] #2608504
01/18/19 11:42 AM
01/18/19 11:42 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
What you don't need is a disc/drum combination valve, which is what you have right now.
You may, or may not need a proportioning valve depending on how well you did your homework. If you choose the wrong sized rear caliper you may need a proportioning valve to dial out any rear wheel lockup.
Don't be the exception.
Re: rear disc brake / prop valve question conversion [Re: cudaerik] #2608553
01/18/19 01:19 PM
01/18/19 01:19 PM
moparx Online content
moparx  Online Content
what brand is that block ?
beer
Re: rear disc brake / prop valve question conversion [Re: superchuck] #2608565
01/18/19 01:53 PM
01/18/19 01:53 PM
AndyF Offline
AndyF  Offline
You left out too much information so the only answer that fits is "it depends".
Re: rear disc brake / prop valve question conversion [Re: moparx] #2609828
01/21/19 12:55 PM
01/21/19 12:55 PM
Norway
cudaerik Offline
cudaerik  Offline
Norway
picture is from Dr. Diff
Re: rear disc brake / prop valve question conversion [Re: cudaerik] #2609869
01/21/19 02:20 PM
01/21/19 02:20 PM
thank you !
beer
