Neon Proportioning Valve #2606646
01/14/19 10:16 PM
01/14/19 10:16 PM
Spring Hill Fl
65Fury440 Offline OP
Spring Hill Fl
MOPAR 5015181AA
https://www.summitracing.com/parts/mop-05015181aa/applications
Does this act as a residual pressure valve?
Re: Neon Proportioning Valve [Re: 65Fury440] #2606791
01/15/19 05:20 AM
01/15/19 05:20 AM
Spring Hill Fl
Spring Hill Fl
Anyone?
Re: Neon Proportioning Valve [Re: 65Fury440] #2606817
01/15/19 10:44 AM
01/15/19 10:44 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Don't know, but I've had to replace mine. Ask over at neons.org After thinking about it a bit, I wouldn't think so, cause Neon brakes aren't split front and rear, but diagonally, so that means there would be residual pressure on the front also. But, I could also be wrong, just thinking out loud.
Re: Neon Proportioning Valve [Re: 65Fury440] #2606837
01/15/19 11:40 AM
01/15/19 11:40 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I think the bird has the word, not to mention that thing is likely metric thread.
Don't be the exception.
Re: Neon Proportioning Valve [Re: 71birdJ68] #2607097
01/15/19 07:24 PM
01/15/19 07:24 PM
Spring Hill Fl
Spring Hill Fl
They really do that with a disc/drum setup? wow...
@Supercuda, yes one would think so but, no, it uses fractional sizes.
Thanks guys!
Re: Neon Proportioning Valve [Re: 65Fury440] #2607361
01/16/19 07:28 AM
01/16/19 07:28 AM
ohio
ruderunner Online content
ruderunner  Online Content
ohio
Diagonal split is common for front wheel drive cars, has been for a long time.
What is the reason for replacing the existing valve?
Angry white pureblood male
Re: Neon Proportioning Valve [Re: 65Fury440] #2608313
01/17/19 11:11 PM
01/17/19 11:11 PM
Spring Hill Fl
Spring Hill Fl
Doing a disc conversion, While looking at residual pressure valves, this came up. The aftermarket M/Cs dont come with a RPV.
Looked like it would be a clean way to install a valve for the rear drums.
Re: Neon Proportioning Valve [Re: 65Fury440] #2608334
01/17/19 11:52 PM
01/17/19 11:52 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
modern wheel cylinder design doesn't require RPV's.
But if you need some
https://www.speedwaymotors.com/shop/residual-valves~8-39207
Re: Neon Proportioning Valve [Re: Supercuda] #2608630
01/18/19 03:37 PM
01/18/19 03:37 PM
Spring Hill Fl
Spring Hill Fl
Any idea what year the cutoff between need an RPV and you don't?
I replaced the wheel cylinders about 6 years ago, they seemed to be the same as the cylinders that were on there. But in all fairness, I wasn't looking at the old parts with any kind of details inside.
Re: Neon Proportioning Valve [Re: 65Fury440] #2608754
01/18/19 08:49 PM
01/18/19 08:49 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
They look like this
https://www.rockauto.com/en/moreinfo.php?pk=370214&cc=1417700&jsn=405
that for a 65 Fury
no idea of the cut off or for that matter if ever aftermarket maker does it.
