What's up with that gap? #2607311
01/16/19 01:45 AM
01/16/19 01:45 AM
Garry Owen Offline OP
So all I've ever messed with is small blocks. Noticed this the other day and haven't found anything on why it's that way. Car seems to run just fine so is it bad or...
Re: What's up with that gap? [Re: Garry Owen] #2607321
01/16/19 02:25 AM
01/16/19 02:25 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Normal. I’m not exactly why the heat crossover is designed that way. But don’t worry about it.
Re: What's up with that gap? [Re: StealthWedge67] #2607323
01/16/19 02:35 AM
01/16/19 02:35 AM
I would say that it is to dissipate heat.
Re: What's up with that gap? [Re: Garry Owen] #2607509
01/16/19 02:56 PM
01/16/19 02:56 PM
Colorado front range
BcudaChris Offline
BcudaChris  Offline
Its part of the heat crossover to warm the plenum on a factory intake. Most aftermarket intakes do not have the corresponding upper passageway, or have no passageway at all. Some intake gaskets will cover it completely.
I've run my junk like yours is setup with no problems. That exposed passage will attract crud, but that's about it.
Re: What's up with that gap? [Re: Garry Owen] #2607544
01/16/19 03:34 PM
01/16/19 03:34 PM
All the OEM iron BB heads except the Max wedge heads have that feature built into them to help reduce the heat from the cross over passage from the passenger side of the motor forced to the drivers side with stock exhaust manifolds to help heat up the intake manifolds shruggy
I don't think Mopar or any other of the car makers have that feature on any other motor confused
Re: What's up with that gap? [Re: Cab_Burge] #2607563
01/16/19 03:55 PM
01/16/19 03:55 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
You're all wrong, it's the equivalent of Limbo for small items you accidently drop.
Re: What's up with that gap? [Re: John_Kunkel] #2607582
01/16/19 04:18 PM
01/16/19 04:18 PM
John you're the man (as always!).
Re: What's up with that gap? [Re: John_Kunkel] #2607599
01/16/19 04:38 PM
01/16/19 04:38 PM
moparx Online content
moparx  Online Content
it is as the factory intended. a place for small items you desperately need to be stored [in a safe place], or to make you think you dropped down the carb port, forcing you to tear down the top end, only to find nothing ! laugh2
beer
Re: What's up with that gap? [Re: Garry Owen] #2607738
01/16/19 09:21 PM
01/16/19 09:21 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
By the way, your small blocks were that way, too...
Re: What's up with that gap? [Re: John_Kunkel] #2607739
01/16/19 09:21 PM
01/16/19 09:21 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Carburetor linkage retainers/clips for example
( don't ask me how I know it )
Re: What's up with that gap? [Re: Garry Owen] #2607789
01/16/19 10:47 PM
01/16/19 10:47 PM
Kirkland, Washington
Pacnorthcuda Offline
It's also where you store 1970's grit and goo.
Re: What's up with that gap? [Re: John_Kunkel] #2607795
01/16/19 11:00 PM
01/16/19 11:00 PM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
Old timer told me that's where he always shoved his cigarette butts.
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: What's up with that gap? [Re: Jim_Lusk] #2607857
01/17/19 12:47 AM
01/17/19 12:47 AM
Never really noticed. Intake always covered it I guess. I wanna say thanks Jim, went back a looked at the picture and seen I have a carb leak. Great...
