Body Plug Retainer, 70 Cuda #2605906
01/13/19 03:18 PM
01/13/19 03:18 PM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
In a 1970 Cuda, rear floor pan, closest to the tunnel, is a metal (OD Green Chromate) body plug with an orange rubber gasket. This plug is held into place by a flat sheet speed nut, 10-24 (as stamped on it), with turned down corners, 1.3” X 1/2” X .022 THK. As seen in the photo one of mine is cracked. I’ve searched all over locally with no luck, scoured the internet and managed to find a company that makes one, problem is they don’t stock them and asked how many thousands I’d like to buy. I even went to the junk yard and due To various factors, to include almost no e-bodies, turned up empty pockets. Don’t get me wrong, speed nuts are available, the issue is the length.
So the question is where do you get one?
If nowhere, anyone have one from a stripped car they won’t be using?
Is this unique to Cudas?
I’m sure some may say throw a rubber body plug in it but I can’t do that
Re: Body Plug Retainer, 70 Cuda [Re: AAR#2] #2605909
01/13/19 03:23 PM
01/13/19 03:23 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
This is the type used on AARs & T/As due to the extra heat from the side exit exhaust under that section of rear floor.
Re: Body Plug Retainer, 70 Cuda [Re: AAR#2] #2605940
01/13/19 04:10 PM
01/13/19 04:10 PM
BDW Offline
BDW  Offline
Have it TIG welded?
Re: Body Plug Retainer, 70 Cuda [Re: AAR#2] #2605953
01/13/19 04:41 PM
01/13/19 04:41 PM
MA
steve70 Offline
steve70  Offline
MA
1970 Challenger T/A 4 speed
Re: Body Plug Retainer, 70 Cuda [Re: AAR#2] #2605969
01/13/19 04:58 PM
01/13/19 04:58 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Odd cutout / tab in those?
Re: Body Plug Retainer, 70 Cuda [Re: steve70] #2605973
01/13/19 05:02 PM
01/13/19 05:02 PM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
Originally Posted By steve70
Those are the shock tower ones, not the same and the under side speed nut isn’t the same either
Re: Body Plug Retainer, 70 Cuda [Re: BDW] #2605977
01/13/19 05:05 PM
01/13/19 05:05 PM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
Originally Posted By BDW
Have it TIG welded?
I could do that but this is really thin spring steel, likely become very brittle after welding, this may be a last resort
Re: Body Plug Retainer, 70 Cuda [Re: Alaskan_TA] #2605986
01/13/19 05:21 PM
01/13/19 05:21 PM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
Well that would explain my lack of ability to find one in the junkyard, unsure why that didn’t cross my mind.
Re: Body Plug Retainer, 70 Cuda [Re: Alaskan_TA] #2607195
01/15/19 09:48 PM
01/15/19 09:48 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
Ive seen that plug used on other E bodies in the floorpan, not just T/A's and AAR's
