Mopar EFI article in Hot Rod #2606777
01/15/19 03:09 AM
01/15/19 03:09 AM
AndyF Offline OP
AndyF  Offline OP
https://www.hotrod.com/articles/adding-h...ig-block-mopar/
Coil near plug with port injection on my 514 inch big block. The long block was sold earlier this year but I still have some of the EFI parts sitting on the shelf. That was a good engine, it made a lot of power for a lot of dyno pulls.
Re: Mopar EFI article in Hot Rod [Re: AndyF] #2606798
01/15/19 08:51 AM
01/15/19 08:51 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
Very nice Andy!
Re: Mopar EFI article in Hot Rod [Re: quickd100] #2606905
01/15/19 01:37 PM
01/15/19 01:37 PM
moparx Offline
moparx  Offline
i always enjoy your hot rod and car craft articles andy ! up thanks for doing them !
beer
Re: Mopar EFI article in Hot Rod [Re: AndyF] #2606942
01/15/19 02:41 PM
01/15/19 02:41 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Nice work. There is really alot going on in every picture.
Re: Mopar EFI article in Hot Rod [Re: AndyF] #2607026
01/15/19 05:05 PM
01/15/19 05:05 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Thanks for the reference in the article.
Re: Mopar EFI article in Hot Rod [Re: ZIPPY] #2607061
01/15/19 06:18 PM
01/15/19 06:18 PM
AndyF Offline OP
AndyF  Offline OP
Yeah there is a ton of custom fabrication involved but most people won't notice it since they don't know any better. Anyone who has tried to build this stuff will see it though. In a couple of pictures almost everything in the frame is custom fabbed.
Not sure if I'll ever do another project quite as involved as that one.
Re: Mopar EFI article in Hot Rod [Re: AndyF] #2607404
01/16/19 11:36 AM
01/16/19 11:36 AM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
we make a lot of these parts off the shelf now. save yourself the headache of custom fabbing everything. we will be releasing coil brackets that bolt on over the valve covers here soon, for both big blocks and small blocks.
our cam sensor bushings and mopar crank trigger kits are always popular with 36-1 trigger options and 24x trigger wheel options. and they can bolt onto a stock pulley without moving all the accessories.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: Mopar EFI article in Hot Rod [Re: AndyF] #2607450
01/16/19 01:28 PM
01/16/19 01:28 PM
Netherlands
72Challenger Offline
Netherlands
Jerry, migth want to change the webaddress in your sig by adding a - to it...
Re: Mopar EFI article in Hot Rod [Re: 72Challenger] #2610670
01/22/19 09:09 PM
01/22/19 09:09 PM
CA
Stuntman Bill Offline
CA
Yes, the URL in your sig is not resolving correctly. Tried it last night, tried it again just now: "sd-concepts" works but "sdconcepts" resolves to a blank page.
Re: Mopar EFI article in Hot Rod [Re: Stuntman Bill] #2610768
01/22/19 11:35 PM
01/22/19 11:35 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Andy,
Thank you for laying all of this out. I'm going to follow your EFI build lock step with an EFI Live dash and Dominator ECU.
It will take years off of my project compared to if we had to figure it out in house.
If you have any low deck stuff I'd be interested in a list.
I'm surprised you didn't reuse the injection system for a future build. Any insight on what the next test mule will be?
Re: Mopar EFI article in Hot Rod [Re: AndyF] #2610798
01/23/19 12:29 AM
01/23/19 12:29 AM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Jeremiah:
I can provide you with everything you need including the AR CNP parts which I stock.
Re: Mopar EFI article in Hot Rod [Re: Jeremiah] #2610864
01/23/19 03:19 AM
01/23/19 03:19 AM
AndyF Offline OP
AndyF  Offline OP
I have a complete low deck EFI setup that is going into my Duster. The RB intake with injectors, fuel lines and throttle body is just sitting on the shelf for now. I'm planning on selling all of that stuff but haven't gotten around to posting an ad yet. As Rich said, the sensors, cam sync, trigger wheel setup, etc. are all available from him.
