Crank thrust repair #2606635
01/14/19 09:41 PM
01/14/19 09:41 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
I have a 1st gen hemi crank with a thrust journal that is worn and too wide. Otherwise its a good crank. I'm nor sure if they're forged or cast bet either way am wondering if there's a repair method.
Re: Crank thrust repair [Re: Stanton] #2606643
01/14/19 10:05 PM
01/14/19 10:05 PM
A Red State
SNK-EYZ Online tonguue
SNK-EYZ  Online Tonguue
A Red State
Whether it cast or forged, weld it up and machine it is all you can do other than replacing it.
Re: Crank thrust repair [Re: Stanton] #2606645
01/14/19 10:15 PM
01/14/19 10:15 PM
New Jersey, USA
Y
yella71 Offline
yella71  Offline
Y
New Jersey, USA
Its a forged crank, and as said it gets welded and machined to repair.
71 challenger convertable, 64 sport fury 383 ci with factory air 99 sebring convertable 89 CTD pup
Re: Crank thrust repair [Re: Stanton] #2606655
01/14/19 10:48 PM
01/14/19 10:48 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Kinda figured that.
Re: Crank thrust repair [Re: Stanton] #2606678
01/14/19 11:25 PM
01/14/19 11:25 PM
Originally Posted By Stanton
Kinda figured that.
Can you have the thrust chromed and restored to stock specs? If so that is the hot ticket up scope twocents
Re: Crank thrust repair [Re: Cab_Burge] #2607074
01/15/19 06:40 PM
01/15/19 06:40 PM
dogdays Offline
dogdays  Offline
ALL GI and GII Hemi cranks and rods are forged. Mopar didn't start using cast cranks anywhere until about 1967, on the LAs. And they've never used a cast rod AFAIK.
It's as simple as welding it up and grinding to size. Not terribly easy because crank grinders aren't meant to grind sideways. But it's done all the time.
R.
