Indy block lifter bore upgrades #2606155
01/13/19 10:00 PM
01/13/19 10:00 PM
Charlotte, North Carolina
sgcuda Offline OP
sgcuda  Offline OP
I have an early aluminum solid RB Indy block that is machined for standard diameter lifters without oil. Is there enough room to bore it out and bush it for .937 keyway lifters? I have no idea how much material is on the sleeves or how much aluminum you need around them.
Re: Indy block lifter bore upgrades [Re: sgcuda] #2606191
01/13/19 11:04 PM
01/13/19 11:04 PM
AndyF Offline
AndyF  Offline
Best bet is to buy one of the sleeves from Jesel so you can measure it. Then you'll know for sure.
Re: Indy block lifter bore upgrades [Re: sgcuda] #2606486
01/14/19 04:01 PM
01/14/19 04:01 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
That would tell you how much is left but really wouldn't tell you if that is enough. I would call somebody that works on those blocks a lot and ask them if they have done it and if it holds up.
2011 Drag Pak Challenger
Re: Indy block lifter bore upgrades [Re: rickseeman] #2606488
01/14/19 04:04 PM
01/14/19 04:04 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Call Chuck at Best Machine.
Re: Indy block lifter bore upgrades [Re: sgcuda] #2606515
01/14/19 05:00 PM
01/14/19 05:00 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
The Jesel bushing for .937 keyway lifter has a OD of 1.062 I would think a solid block would have more meat in the area but the machine shop would know for sure. Proper placement of the bore hole is the most important thing.
Re: Indy block lifter bore upgrades [Re: Mopar_Rich] #2606578
01/14/19 07:19 PM
01/14/19 07:19 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
Best source for this information, or better yet, let him do it for you
....BAD A$$ STREET CAR.....
