#2606454 - 01/14/19 11:24 AM 340 cam plate bolt hole ?
calrobb2000 Offline
Loc: s. e. pa.
hi
rebuilding a 340 and need to know the size of the oil hole in the 1 bolt that holds the cam plate on .
the one i have looks large to me like someone may have inlarged the hole size ?
thank you !
#2606483 - 01/14/19 12:49 PM Re: 340 cam plate bolt hole ? [Re: calrobb2000]
gtsdude Offline
Loc: S.E. Minnesota
Don't think it really matters, some came without a bolt at all.
#2606539 - 01/14/19 02:52 PM Re: 340 cam plate bolt hole ? [Re: calrobb2000]
Loc: Lincoln Nebraska
it was an 1/8" hole (in the bolt). early or late (I forget which) had the bolt w hole & the other (early or late) had the drip tray that elim'd that bolt. that is drip oiling & for the ultimate you could drill a .015 (1/64) hole in an alum NPT pipe plug & drill/tap/thread it into the front of the pass horizontle oil gallery & a 3/8 hole in the cam plate for it to squirt out onto the chain. Shorten this pipe plug as to not block off oil down to the #1 main/drivers side gallery (that would be disastrous!). Maybe the chain gets enough splash as is but its fun to mod things & evidently some was needed cuz Ma did the drip oiling. Do the same (.015) in a 3/8 alum pipe plug next to the intergear at the other end/side.
25,741 Registered Members
192,936 Topics
WIW: Stock LA Motor Connecting Rods
by vinnyd76
Today at 12:12 PM
What would win, road grader vrs MGB?
by GODSCOUNTRY340
Today at 12:03 PM
EMISSIONS CODE P0440
by moparsquid
Today at 11:30 AM
Brake calipers
by scottyb1955
Today at 11:17 AM
