Re: SHOCKS FOR SS SPRINGS
[Re: A/MP]
#2605745
01/13/19 04:16 AM
01/13/19 04:16 AM
Posts: 10,553 Rittman Ohio
fourgearsavoy
Rittman Ohio
Next question is budget and intended usage. My car has SS springs and I am happy with the Rancho XL 9000 adjustables. It's just a single adjustable that I dial down to 2 for street driving and set them on 8 for a nice launch on the track. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: wkroncke17]
#2605922
01/13/19 03:42 PM
01/13/19 03:42 PM
Posts: 19,396 north of coder
moparx
Going to follow this closely. Doing a similar build but am using 1ā lowering blocks so the back end is not so high in the air. the rear may be sat higher on the springs due to the blocks, but the shock plate will still be in the same location, blocks or not. unless you have a custom built shock mounting plate, the length will be the same and need the same travel, but the rear being on blocks may require a different adjustment or shock than the rear without using blocks. something to think about, but i am FAR from being an expert by any stretch of the imagination.
[Re: moparx]
#2606308
01/14/19 03:44 AM
01/14/19 03:44 AM
Posts: 2,808 Wisconsin
wkroncke17
Wisconsin
Going to follow this closely. Doing a similar build but am using 1ā lowering blocks so the back end is not so high in the air. the rear may be sat higher on the springs due to the blocks, but the shock plate will still be in the same location, blocks or not. unless you have a custom built shock mounting plate, the length will be the same and need the same travel, but the rear being on blocks may require a different adjustment or shock than the rear without using blocks. something to think about, but i am FAR from being an expert by any stretch of the imagination. Great point! Thank you! As you can tell, Iām no expert either. At 50, still learning every day!
