Dana 60 housing 2.750 axle tubes #2605693
01/13/19 12:55 AM
01/13/19 12:55 AM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
I have a bare housing which I cannot positively identify.
If I use it, my intent is to narrow it, use Mopar ends and
internals and custom axles.
It is a "501" casting which I think is very similar to an
old Jeep Dana 60-2 rear housing, which is essentially a 60
with 44 tubes. Cast spring pads 40" apart, 6-bolt flanges.
Unless it is particularly rare for someone who would use it
as is, I would cut & weld it.
So really, my question is, would you use this housing in a
Hemi E-body with street tires, or should I get a housing
with 3 inch or 3 1/8 inch tubes ?
Re: Dana 60 housing 2.750 axle tubes [Re: hemienvy] #2605706
01/13/19 01:24 AM
01/13/19 01:24 AM
It sounds to me like YOU have YOUR doubts about it so go with what makes you happy up twocents
another thing is are you going to use stock type U bolts to hold the rear end onto leaf springs? If so go with the 3.0 inch axle tube housings up work
Re: Dana 60 housing 2.750 axle tubes [Re: Cab_Burge] #2605711
01/13/19 01:31 AM
01/13/19 01:31 AM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
You are correct ! I do have doubts, but my doubts could be
erased by someone with more knowledge than I.
Bigger axles tubes would be stronger but maybe unnecessarily
heavy, I don't know. What size were the B-body Dana's ?
Also it's cheaper if I don't need to buy another housing.
Re: Dana 60 housing 2.750 axle tubes [Re: hemienvy] #2605714
01/13/19 01:36 AM
01/13/19 01:36 AM
Both the 8 3/4 and made for Mopar OEM Dana 60 have 3.0 axle tubes up
Re: Dana 60 housing 2.750 axle tubes [Re: hemienvy] #2605724
01/13/19 02:26 AM
01/13/19 02:26 AM
nj
JAMESDART Offline
JAMESDART  Offline
nj
I had a housing like that. No idea what it was from, a seller on eBay had a load of nos housings for like 50$ each of something.
Re: Dana 60 housing 2.750 axle tubes [Re: hemienvy] #2605725
01/13/19 02:34 AM
01/13/19 02:34 AM
Minnesota, USA
humpty Offline
humpty  Offline
Minnesota, USA
I'd pass on it and find a 3'". I've found several complete units in my area for $100. Then all the factory ubolts and plates fit.
Re: Dana 60 housing 2.750 axle tubes [Re: humpty] #2605778
01/13/19 10:26 AM
01/13/19 10:26 AM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I would find another housing with the bigger tubes, they are out there and not that scarce, I would be concerned about the tube thickness on yours, it may be ok but you will not know untill you cut it, also the mopar ends are designed for the 3" tube size.
Re: Dana 60 housing 2.750 axle tubes [Re: hemienvy] #2605781
01/13/19 10:49 AM
01/13/19 10:49 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I believe they are a Ford van housing. Also ask, I believe Dr diff can retube it to 3".
Doug
Re: Dana 60 housing 2.750 axle tubes [Re: hemienvy] #2605823
01/13/19 12:42 PM
01/13/19 12:42 PM
nj
JAMESDART Offline
JAMESDART  Offline
nj
The one I had still had thick tubes, 1/4 or 5/16. I narrowed it, put new ends and perches on it. on it and just went with it. You could just tack 1/8 flat bar in a C to space the u bolts. I’d use it, if I already had it.
Re: Dana 60 housing 2.750 axle tubes [Re: hemienvy] #2605923
01/13/19 03:43 PM
01/13/19 03:43 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Why not stay true MOPAR and use a 9-1/4" housing since you have to do all the work and get all the guts anyway. They're dirt cheap, plentyful and strong.
Re: Dana 60 housing 2.750 axle tubes [Re: Stanton] #2605932
01/13/19 03:50 PM
01/13/19 03:50 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
How thick are the tubes on a 3-inch tube Dana ?
Re: Dana 60 housing 2.750 axle tubes [Re: hemienvy] #2605939
01/13/19 04:07 PM
01/13/19 04:07 PM
They vary in thickness depending on the application, car, pickup or van shruggy
Re: Dana 60 housing 2.750 axle tubes [Re: hemienvy] #2605992
01/13/19 05:29 PM
01/13/19 05:29 PM
Washington
madscientist Offline
Washington
I had a truck D60 and IIRC it had .250 wall tubes. I welded the tubes to the center section and used Summers Bros. 40 spline axles those things were art. Too bad they are no more.
Re: Dana 60 housing 2.750 axle tubes [Re: madscientist] #2606015
01/13/19 06:03 PM
01/13/19 06:03 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
the dana 60 in my car came from a early 70's Ford 4X4 and had the 3.125 diameter tubes,and was a floater style, had to trim all my brackets to fit the larger diameter,, seem that Ford was good for using that size.
Re: Dana 60 housing 2.750 axle tubes [Re: hemienvy] #2606061
01/13/19 07:14 PM
01/13/19 07:14 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
A lot of pickups had 1/2" tubes if they were 3/4 ton, there were also a lot of 5/16 and 1/4 tubes in lighter duty applications.
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
