Re: Dana 60 housing 2.750 axle tubes
[Re: hemienvy]
#2605706
01/13/19 01:24 AM
01/13/19 01:24 AM
Posts: 43,157 Bend,OR USA
Cab_Burge
[Re: humpty]
#2605778
01/13/19 10:26 AM
01/13/19 10:26 AM
dartman366
Mt. Vernon, Ohio
I would find another housing with the bigger tubes, they are out there and not that scarce, I would be concerned about the tube thickness on yours, it may be ok but you will not know untill you cut it, also the mopar ends are designed for the 3" tube size.
[Re: hemienvy]
#2605939
01/13/19 04:07 PM
01/13/19 04:07 PM
Cab_Burge
How thick are the tubes on a 3-inch tube Dana ? They vary in thickness depending on the application, car, pickup or van
[Re: hemienvy]
#2605992
01/13/19 05:29 PM
01/13/19 05:29 PM
Posts: 4,457 Washington
madscientist
Washington
I had a truck D60 and IIRC it had .250 wall tubes. I welded the tubes to the center section and used Summers Bros. 40 spline axles those things were art. Too bad they are no more.
[Re: madscientist]
#2606015
01/13/19 06:03 PM
01/13/19 06:03 PM
dartman366
Mt. Vernon, Ohio
the dana 60 in my car came from a early 70's Ford 4X4 and had the 3.125 diameter tubes,and was a floater style, had to trim all my brackets to fit the larger diameter,, seem that Ford was good for using that size.
[Re: hemienvy]
#2606061
01/13/19 07:14 PM
01/13/19 07:14 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
A lot of pickups had 1/2" tubes if they were 3/4 ton, there were also a lot of 5/16 and 1/4 tubes in lighter duty applications.
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
