Page 3 of 4 1 2 3 4
Re: D-60 vs 9"....here we go again.... [Re: hemienvy] #2604568
01/10/19 07:24 PM
01/10/19 07:24 PM
an8sec70cuda Offline
One thing to consider is the bending of axle tubes. This was always something Monte Smith pointed out. At high power levels, you can't stop the tubes from bending on a Dana. 9" rears have all sorts of stronger housings and their design makes them easy to brace up real good.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: D-60 vs 9"....here we go again.... [Re: an8sec70cuda] #2604593
01/10/19 08:13 PM
01/10/19 08:13 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
iagree The Dana housing in my car is bent and I'm not at a really high power level so it only takes a heavy stick car with a stiff clutch and medium traction to bend one.
There are some guys that brace them with tubes and heims like the 8.8 Ford guys do.
I'm not sure the back brace tubes do any thing with the Ultimate 60 covers have but it looks cool biggrin
Gus beer
64 Plymouth Savoy
Dana 60
Re: D-60 vs 9"....here we go again.... [Re: fourgearsavoy] #2604600
01/10/19 08:24 PM
01/10/19 08:24 PM
Rittman Ohio
Rittman Ohio
Maybe forget all this nonsense and put a Rockwell F106 truck rear in the car laugh2
Gus beer
64 Plymouth Savoy
Dana 60
Re: D-60 vs 9"....here we go again.... [Re: hemienvy] #2604606
01/10/19 08:39 PM
01/10/19 08:39 PM
Kirkland, Washington
Pacnorthcuda Offline
That looks really expensive...
Re: D-60 vs 9"....here we go again.... [Re: hemienvy] #2604643
01/10/19 09:34 PM
01/10/19 09:34 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I don't know how much power it takes to bend Dana tubes? But mine hasn't bent them in 525+ passes at somewhere north of 900hp. 1.25-1.30 60ft@3350lbs (or 3500lbs+ with ballast). The first Motive street gear went 425 passes before it bent a tooth. The 2nd no name street gear only went 100 passes before it broke pinion teeth. This time it got a US gear Pro Gear. I also added the LPW cover like shown above. Braces were not added at this time. We'll go do some real word testing and see what happens,
Doug
Re: D-60 vs 9"....here we go again.... [Re: WHITEDART] #2604651
01/10/19 09:43 PM
01/10/19 09:43 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
Originally Posted By WHITEDART
Originally Posted By Cab_Burge
Me thinks the 40 spline axles gun drill lightweight option are a better choice for both rear ends work twocents
this is what I was told as well . And I can tell you first-hand a 40 spline with a big gun drill. Was lighter than my 31-spline that wasn't drilled
OK since I'm chasing light 9" with aluminum center section and gun drilled 40 spline? Do they make gun drilled 35 spline?
Re: D-60 vs 9"....here we go again.... [Re: Biginchmopar] #2604693
01/10/19 11:14 PM
01/10/19 11:14 PM
Rittman Ohio
Rittman Ohio
Strange charges around $140.00 a pair to drill 35 spline axles when you order them.
Mark Williams will also drill 35 spline axles but I'm not sure what they charge
Gus beer
64 Plymouth Savoy
Dana 60
Re: D-60 vs 9"....here we go again.... [Re: Biginchmopar] #2604695
01/10/19 11:16 PM
01/10/19 11:16 PM
I tried to buy the lightweight gun drill axles from Strange for my 1965 Dart S/P car and I ended up letting the female sale clerk talk me out of them realcrazy whiney
I was planning on ordering the gun drilled lightweight 40 splines at first and she talk me down to the standard 35 spline race axles due to it being a "bracket car" whiney realcrazy
Never again will I let someone talk me out of better parts down especially in the drive train twocents
Re: D-60 vs 9"....here we go again.... [Re: dvw] #2604705
01/10/19 11:26 PM
01/10/19 11:26 PM
Rittman Ohio
Rittman Ohio
Doug
I think mine may have happened before I got some better shocks on my car. I was racing at the Chrysler classic event about 4 years ago and it hooked hard and unloaded the suspension and bounced the left rear tire off the track. My buddy actually took picture and the car had 3 wheels off the ground. It also bent the wheel studs enough that I had to cut them off to unscrew them from the axles.
Ever since then the axles are hard the get in and out of the housing. They are Moser 35 spline axles and spool installed a 67 factory Mopar housing. It was a violent launch and I'll never put a 5500 chip in the 2 step again.
Gus beer
64 Plymouth Savoy
Dana 60
Re: D-60 vs 9"....here we go again.... [Re: fourgearsavoy] #2604710
01/10/19 11:32 PM
01/10/19 11:32 PM
I would take a pair of 24 inch long carpenter squares using a helper to measure the toe in and toe out off of the axles flanges out 15 to 18 inches in front and back to see if the housing is bent or not scope wrench
Better to find it now and stop the damage before it hurts you and the car work twocents
Re: D-60 vs 9"....here we go again.... [Re: Cab_Burge] #2604719
01/10/19 11:43 PM
01/10/19 11:43 PM
Rittman Ohio
Rittman Ohio
I put the car up on the alignment rack at work and the rear alignment was pretty straight. Very slight difference between right and left.Not enough to be in the red anyway but it wouldn't take much to make the axles bind up in the splines. I recently installed a PowerLock unit with brand new upgraded spider gears and it was even worse with brand new splines.
There is a rear end shop about 40 minutes away that can straighten my housing and re-tube it with chrome molly tubes if necessary.
This is the deal that the Mustang guys are running shruggy
Gus beer
64 Plymouth Savoy
Dana 60
Re: D-60 vs 9"....here we go again.... [Re: Cab_Burge] #2604798
01/11/19 08:58 AM
01/11/19 08:58 AM
Mo.
racerx Online work
racerx  Online Work
Mo.
she musta had a pretty voice...……... laugh2
Re: D-60 vs 9"....here we go again.... [Re: hemienvy] #2604828
01/11/19 11:43 AM
01/11/19 11:43 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I think she had a valid point for you Cab...
I noted last spring checking some stuff out that it was more difficult removing my right axle. Really not bad enough to worry about it, but noted. Possibly one of the times ladder mounts were welded on? I hardly think I’m making enough power to do it.
Re: D-60 vs 9"....here we go again.... [Re: hemienvy] #2604872
01/11/19 12:49 PM
01/11/19 12:49 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
I have the gun drilled lightweight 35 spine axles from moser engineering in my S-60 - This rear-end was in a FAST car for about 20 passes and was replaced with an 8-3/4 for weight saving - it also has a lightweight spool and the big Ford bearing on the axles - all for weight savings
Re: D-60 vs 9"....here we go again.... [Re: hemienvy] #2604943
01/11/19 02:17 PM
01/11/19 02:17 PM
fla
ss/la Offline
ss/la  Offline
fla
the dana 60 is faster and stronger than a 9 in. the popularity of a 9 is being able to change center sections faster. the popularity is why gear companys have more ratio selections. you all have to remember it is not horsepower that breaks driveline parts, its all about car weight. a 500 hp car at 4000 pounds will break more driveline parts than a pro stock car will. if pure strength is all you are after and are not going to change ratios dana 60 all day long my car has had the same gear in it since 1999 when the car was built and that is using a trans brake too. it will 60 ft 1.33 at 3360 pounds
Re: D-60 vs 9"....here we go again.... [Re: an8sec70cuda] #2605031
01/11/19 05:49 PM
01/11/19 05:49 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Originally Posted By DusterKid
Originally Posted By fourgearsavoy
Like always the "stock" Dana is stronger than a "stock" 9"
Now build a 9" without ANY Ford parts then the race is on. Three bearings to support the pinion against the ring gear will ALWAYS be better than two twocents
And yes it will cost about twice as much but in the end you will have a better unit.
Still have a Dana in my car though work
Gus beer
100% agree
iagree Build one w/ good parts and the 9" is better.
That efficiency argument is a wash. You'll never see it, unless you're in a low powered class car that needs every tiny ounce of free movement to run a number. The benefits of an aftermarket 9" far outweigh any efficiency issue.
This is all true.
Re: D-60 vs 9"....here we go again.... [Re: BobR] #2605051
01/11/19 06:20 PM
01/11/19 06:20 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Gus beer
100% agree
This is all true.
I agree but still run a Dana 60. Most of my buddies all have there cars dialed in with 9", so the simplicity of being able to do a quick gear change never matters anyway. They have been running the same gear ratio for years now. The major benefit beside new parts availability is to build a spare center section & to have in the trailer if you break one.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: D-60 vs 9"....here we go again.... [Re: BobR] #2605053
01/11/19 06:22 PM
01/11/19 06:22 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
This is a good and informative post. I don't mind rehashing this stuff once in a while as it clears out the cobwebs.
My only [censored] about the S-60 in my red car is that they didn't box the spring perches.
If I had a decent fab shop that could make a housing locally I'd have gone 9". The dana was easier because I could order it and know it will fit based on what was in the car. We were very hesitant to send a pile of money and a build sheet several states away and hope everything fit when it showed up.
What can I say my dealings with Lenco made me very gun shy when it comes to ordering custom big dollar (for this household) items from afar. 90% of my dealings with the "big names" in high performance were rather disappointing.
That said the 10% that lived up to their reputations kept me in the chase for a fast manual trans street car. They all recognized and rewarded hard work.
If my big tire car (the black '66) ever needs any major rear overhaul it will get a 9" with a spool as it is a plated strip car.
Re: D-60 vs 9"....here we go again.... [Re: hemienvy] #2605113
01/11/19 08:52 PM
01/11/19 08:52 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
The 9" when done with good aftermarket parts is obiviously the cream of the crop. However for 95% of us here the Dana 60 is a cheaper option. We aren't changing ratios at the track. Though if you set up a 2nd set of gears it would be about as quick. And WAY WAY cheaper. In fact most here can probably get good service life from an 8 3/4. Dollars are hard to come by. Spend them wisely.
Doug
Re: D-60 vs 9"....here we go again.... [Re: hemienvy] #2605127
01/11/19 09:26 PM
01/11/19 09:26 PM
New Jersey, USA
Y
yella71 Offline
yella71  Offline
Y
New Jersey, USA
A 9 in rear was NEVER put behind a diesel engine in a truck. A 9in housing is lighter then a dana 60 ... so it comes down to what it will be used for.
71 challenger convertable, 64 sport fury 383 ci with factory air 99 sebring convertable 89 CTD pup
Page 3 of 4 1 2 3 4
