Indy 440 EZ-1 Heads #2604917
01/11/19 01:39 PM
01/11/19 01:39 PM
Memphis, TN
MoparJason0O0 Offline OP
Memphis, TN
I am going to buy a new set of EZ-1 heads. Who is everyone buying from?
Re: Indy 440 EZ-1 Heads [Re: MoparJason0O0] #2604926
01/11/19 01:46 PM
01/11/19 01:46 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Welcome to the jungle!
Check out Porter Racing Heads: Dwayne Porter.
His handle here on moparts is fast68plymouth.
Address: 57 Commerce Ave # 2, South Burlington, VT 05403
Phone: (802) 951-1955
https://www.facebook.com/pages/Porter-Racing-Heads/990347067652818
Rich H.
Esse Quam Videri
Re: Indy 440 EZ-1 Heads [Re: ZIPPY] #2604930
01/11/19 01:48 PM
01/11/19 01:48 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
iagreeThats my guy,top notch and very helpfull before and after,even YEARS after.
Re: Indy 440 EZ-1 Heads [Re: ZIPPY] #2604945
01/11/19 02:26 PM
01/11/19 02:26 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I'd like to add that PRH is also well-equipped to address any machining needs that the typical out-of-the-box Indy heads require to be truly "bolt on".
That doesn't necessarily mean it's the CHEAPEST way to go, but it's certainly the BEST way to go to ensure you're getting a properly prepared set of heads for the application.
Re: Indy 440 EZ-1 Heads [Re: MoparJason0O0] #2605167
01/11/19 10:43 PM
01/11/19 10:43 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
Yep I will have to agree with everyone on this one PRH is a great guy to deal with.
If you look at my signature it kinda tells the story about my Indy EZ-1 experience
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: Indy 440 EZ-1 Heads [Re: MoparJason0O0] #2605327
01/12/19 11:26 AM
01/12/19 11:26 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I run a set refreshed by Dwayne Porter as well. Great to deal with, very well informed and extremely experienced.
I would likely go with the CNC'd Trick Flow heads and have Dwayne go over them if I was building a new motor though.
Why are you stuck on the Indy EZ's?
Re: Indy 440 EZ-1 Heads [Re: jbc426] #2605379
01/12/19 02:03 PM
01/12/19 02:03 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
iagree If the Trick Flow heads were available when I built my engine I would have bought them. Much better finish everywhere and the ones I have seen look like you could bolt them on out of the box with only a basic inspection. Not like Indys where you basically have to re-do the valve job and size the guides before you use them.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Indy 440 EZ-1 Heads [Re: ZIPPY] #2606223
01/14/19 12:11 AM
01/14/19 12:11 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Thats where I bought mine. Exellent service and a great guy to deal with. Ron
