#2604917 - 01/11/19 10:39 AM Indy 440 EZ-1 Heads
SpeedRacer Offline
Loc: Memphis, TN
I am going to buy a new set of EZ-1 heads. Who is everyone buying from?
#2604926 - 01/11/19 10:46 AM Re: Indy 440 EZ-1 Heads [Re: SpeedRacer]
ZIPPY Online   content
Loc: S.E. Michigan
Welcome to the jungle!
Check out Porter Racing Heads: Dwayne Porter.
His handle here on moparts is fast68plymouth.
Address: 57 Commerce Ave # 2, South Burlington, VT 05403
Phone: (802) 951-1955
https://www.facebook.com/pages/Porter-Racing-Heads/990347067652818
11.0 @ 123 in street trim
#2604930 - 01/11/19 10:48 AM Re: Indy 440 EZ-1 Heads [Re: ZIPPY]
bonefish Offline
Loc: s.w.fl
iagreeThats my guy,top notch and very helpfull before and after,even YEARS after.
#2604945 - 01/11/19 11:26 AM Re: Indy 440 EZ-1 Heads [Re: ZIPPY]
BradH Offline
Loc: Valhalla... eventually
I'd like to add that PRH is also well-equipped to address any machining needs that the typical out-of-the-box Indy heads require to be truly "bolt on".
That doesn't necessarily mean it's the CHEAPEST way to go, but it's certainly the BEST way to go to ensure you're getting a properly prepared set of heads for the application.
#2605167 - 01/11/19 07:43 PM Re: Indy 440 EZ-1 Heads [Re: SpeedRacer]
67mprfan Online   content
Loc: ohio
Yep I will have to agree with everyone on this one PRH is a great guy to deal with.
If you look at my signature it kinda tells the story about my Indy EZ-1 experience
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere a work in progress
#2605327 - 01/12/19 08:26 AM Re: Indy 440 EZ-1 Heads [Re: SpeedRacer]
jbc426 Offline
Loc: West Coast, USA
I run a set refreshed by Dwayne Porter as well. Great to deal with, very well informed and extremely experienced.
I would likely go with the CNC'd Trick Flow heads and have Dwayne go over them if I was building a new motor though.
Why are you stuck on the Indy EZ's?
1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 3.91's (closest thing to an automatic 5 speed going)
#2605379 - 01/12/19 11:03 AM Re: Indy 440 EZ-1 Heads [Re: jbc426]
fourgearsavoy Offline
Loc: Rittman Ohio
iagree If the Trick Flow heads were available when I built my engine I would have bought them. Much better finish everywhere and the ones I have seen look like you could bolt them on out of the box with only a basic inspection. Not like Indys where you basically have to re-do the valve job and size the guides before you use them.
Gus beer
64 Plymouth Savoy
Dana 60
#2606223 - 01/13/19 09:11 PM Re: Indy 440 EZ-1 Heads [Re: ZIPPY]
383man Offline
Loc: Balt. Md
Thats where I bought mine. Exellent service and a great guy to deal with. Ron
My car...63 Sport Fury Max Wedge wanna be street car..with new 493 pump gas full exh eng.......10.76 @ 124.49 ! ! ! My page on the cool 62-65 Mopar site ! http://www.1962to1965mopar.ornocar.com/mmo82008.html
25,688 Registered Members
196,636 Topics
Correct Front Wheel Cylinders for 10" Drum on an A-Body?
by vinnyd76
01/16/19 10:36 AM
Long rams
by 67R/T4speeder
01/16/19 10:27 AM
Bye Tappen Zee bridge
by bigdad
01/16/19 08:33 AM
Anyone have their 8 track tapes reburbished?
by Charger446
01/16/19 08:30 AM
