Oil Pump O-rings #2604732
01/11/19 12:16 AM
01/11/19 12:16 AM
Missouri
randavis Offline OP
randavis  Offline OP
Missouri
I have an old Direct Connection high volume oil pump kit in my 440. The old o-rings are leaking. Does anyone know the correct dimensions of the o-rings? They are the ones that go between the oil filter adapter and the 1/4" spacer and also between the spacer and the pump body. Just eyeballing, the larger one looks to be approximately 2-5/8" diameter and maybe 3/32" thick. The smaller looks about 3/4" diameter and 3/32" thick. I am not talking about the pump body to block o-ring.
Possible sources?
74 Challenger, bought it new. In 1978 I replaced the original 318 with a 446 and 727. Mild cam, Jardine headers, and Holley Sniper EFI.
New engine! 511" RB, Edelbrock Performer RPM heads, Eagle rotating assy, Comp hyd roller cam, Doug's 2" headers.
Re: Oil Pump O-rings [Re: randavis] #2604739
01/11/19 12:42 AM
01/11/19 12:42 AM
Washington
madscientist Offline
Washington
Possible sources?
Measure what you have and look on the McMaster-Carr web site. They should be able to hook you up.
Re: Oil Pump O-rings [Re: randavis] #2604740
01/11/19 12:42 AM
01/11/19 12:42 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I would visit the local farm equipment dealer or bearing supply house. I know the ones around me would have them shruggy
Gus beer
64 Plymouth Savoy
Dana 60
Re: Oil Pump O-rings [Re: fourgearsavoy] #2604883
01/11/19 12:59 PM
01/11/19 12:59 PM
Missouri
randavis Offline OP
randavis  Offline OP
Missouri
I found them at a hydraulic repair place here in town. $2.76
About the cheapest things I have had to replace on the car!
Thanks for the replies.
