Difference in window regulators from '78 to '79? #2600491
01/02/19 04:14 PM
01/02/19 04:14 PM
Central Florida
larrymopar360 Offline OP
Stud Muffin
Stud Muffin
Central Florida
I see listings for NOS window regulators showing fitment '75 thru '78. Did they really change in '79? I need to get a parts book. I have a '79 W150 with manual windows.
Thank you.
Facts are stubborn things.
Re: Difference in window regulators from '78 to '79? [Re: larrymopar360] #2600600
01/02/19 08:08 PM
01/02/19 08:08 PM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
I can't say for certain...but the only difference I ever came across was that some were riveted in and others were bolt in.
1981 Dodge D150 360 auto
Re: Difference in window regulators from '78 to '79? [Re: larrymopar360] #2601120
01/03/19 08:35 PM
01/03/19 08:35 PM
5thAve Offline
5thAve  Offline
The parts book does show the regular as different part number for 79 and newer. But none of the other parts the door the glass or the inside door panel are different so i would guess that would mean the regulators are interchangeable anyway?
Re: Difference in window regulators from '78 to '79? [Re: larrymopar360] #2601758
01/05/19 12:41 AM
01/05/19 12:41 AM
Middle TN.
4x4 Roundup Offline
4x4 Roundup  Offline
Middle TN.
Thank you.
My parts book does indeed show a different regulator # for 1979-80-81 that being 4113 398-9.
The # for the 1978 is 4082 028-9.
Never had to replace one luck ...yet...so cannot comment on the difference. Hope this helps.
WANTED-- DEAD or ALIVE:
'70 Duster--- VS29H0B274908-----UPDATE---ENGINE BLOCK FOUND---Still looking for the B-5 car.
'79 Power Wagon W14JE9S137761 or 763
Re: Difference in window regulators from '78 to '79? [Re: larrymopar360] #2602774
01/07/19 03:14 AM
01/07/19 03:14 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
I thought the door guts changed in 78 and ran until 86. The vent window and all.
I want my fair share
Re: Difference in window regulators from '78 to '79? [Re: larrymopar360] #2604166
01/09/19 11:23 PM
01/09/19 11:23 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
I am not in need YET. I just re-lubed everything but with no a/c I do crank them up and down frequently, so I would like to keep my eyes open for a spare set. Thank you for information all. Next time I have my panels off I'm going to try and get some decent pics to compare to earlier ones.
4x4 Roundup, thanks for the part numbers. That certainly gives me something to search with!
Re: Difference in window regulators from '78 to '79? [Re: larrymopar360] #2604294
01/10/19 04:11 AM
01/10/19 04:11 AM
Las Vegas, NV
chargerbr549 Offline
Las Vegas, NV
If I remember correctly the drivers and pass side window regulators use the exact same parts they are just assembled differently so pull them apart and reassemble them configured for the opposite side they were originally on and you will have fresh teeth for your window crank gear to mesh up with. Just be careful of the spring set up it can tear up fingers in a hurry.
Re: Difference in window regulators from '78 to '79? [Re: larrymopar360] #2604640
01/10/19 09:30 PM
01/10/19 09:30 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
I've heard that the rollers changed size at some point but not sure when. Might have been in the 80s
Angry white pureblood male
Re: Difference in window regulators from '78 to '79? [Re: larrymopar360] #2611019
01/23/19 01:51 PM
01/23/19 01:51 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
Something changed with rollers, or regulator or track length. Had a 75 I tried to put all the 79 glass in and when you rolled the side window up when it got to the top window would fall down. Can't remember how I fixed it, but was suprised at that.
Re: Difference in window regulators from '78 to '79? [Re: larrymopar360] #2614317
01/29/19 10:50 PM
01/29/19 10:50 PM
South East Ontario, Canada
Ramtough Offline
Ramtough  Offline
Yes the rollers changed, only way to make them work is use regulator, lower glass channel and the roller guide that is spot welded to the door, been there, done that.
Re: Difference in window regulators from '78 to '79? [Re: larrymopar360] #2614320
01/29/19 10:52 PM
01/29/19 10:52 PM
Ramtough Offline
Ramtough  Offline
Oh, BTW, the vent window changed for 78, using the whole frame they fit all the way through72-93
Re: Difference in window regulators from '78 to '79? [Re: Ramtough] #2614478
01/30/19 10:46 AM
01/30/19 10:46 AM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
