Page 1 of 3 1 2 3
Preventing cap walk #2602586
01/06/19 08:37 PM
01/06/19 08:37 PM
Graz, Austria
DGS Offline OP
DGS  Offline OP
Graz, Austria
Just thinking out loud: could you prevent cap walk with roll pins drilled into the parting line between block and cap (parallel to cap bolts)?
Re: Preventing cap walk [Re: DGS] #2602597
01/06/19 09:18 PM
01/06/19 09:18 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
I think the root cause of cap walk is a block that can not handle the power being generated. Most of the OEM muscle car blocks were designed to handle around 400HP, so what happens when you push something twice its designed capacity? A block girdle will help some, as does block filler, but they are just bandaids.
Re: Preventing cap walk [Re: DGS] #2602611
01/06/19 09:44 PM
01/06/19 09:44 PM
Spring Hill Fl
65Fury440 Offline
65Fury440  Offline
Spring Hill Fl
Re: Preventing cap walk [Re: DGS] #2602617
01/06/19 09:52 PM
01/06/19 09:52 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Turn the timing back. It’s cheaper and easier.
Re: Preventing cap walk [Re: 65Fury440] #2602619
01/06/19 09:58 PM
01/06/19 09:58 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I’m not sure how quick you want to go but sometimes we over think things. I’ve gone 8.60’s with 440 blocks and 9.70’s with 360 blocks with no bandaids. Did I have a little cap walk, sure I had some. If I wanted to do a quick stock block 440 again I would put main studs and aluminum caps on it and go racing. Save up your money and get a good block. I did.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Preventing cap walk [Re: DGS] #2602632
01/06/19 10:22 PM
01/06/19 10:22 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
I've even see some guys put bushings around the main studs to help prevent cap walk. it helps some, aluminum main caps on a big block are your number one add on that give you your best bang for your buck. cross bolt caps weaken the block because you have to remove the main webbing that's holding block together.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: Preventing cap walk [Re: TRENDZ] #2602640
01/06/19 10:40 PM
01/06/19 10:40 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
iagree I keep mine at 34* so it doesn't detonate because that is what kills ANY engine twocents
Gus beer
64 Plymouth Savoy
Dana 60
Re: Preventing cap walk [Re: DGS] #2602648
01/06/19 10:58 PM
01/06/19 10:58 PM
AndyF Offline
AndyF  Offline
A man just needs to know his limitations........
In other words if the block you have isn't working for you then upgrade to a better block. If you are going to use a stock block in your project then stay within the limitations of the stock block. You should be able to build a very reliable 600 hp big block engine without having to mess with any bandaids. If you need more than that then either take your chances or step up.
Re: Preventing cap walk [Re: jwb123] #2602657
01/06/19 11:17 PM
01/06/19 11:17 PM
I've found that detonation and poor tuning lead to cap walk even on low compression(less than 9.5 to 1 with iron heads) street engines that make power above 500 HP shruggy
I disagree on using the girdles and block filler down
Not good having cement block filler due to having two different heat ranges in the cylinder walls causing block distortion around the cylinder walls down scope twocents
On using the current after market girdles when you look at the BB Mopar and FE Ford designed blocks that have the main webbing support ribs in the block starting down low around the oil pan rail going up to the upper main bearing webbing using a main girdle that uses the stock 5/16 size oil pan bolts does nothing to strengthen the blocks, does it work scope
Replace the stock main caps and use main studs and spend the left over money on better parts in the stock blocks thumbs twocents
Or better yet do as AndyF suggest, get a better block up work scope
Re: Preventing cap walk [Re: DGS] #2602684
01/07/19 12:03 AM
01/07/19 12:03 AM
Nevada
merpar Offline
merpar  Offline
Nevada
You got it Pittsburgh. Main studs and aluminum main caps. As for those 1/4" thk. main girdles, not even a good band-aid.
Re: Preventing cap walk [Re: DGS] #2602688
01/07/19 12:18 AM
01/07/19 12:18 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Early 360, over 500HP, block filler, under 12:1, good gas, 38 degrees, ARP studs, and they stilled showed fretting. RPM plays into this a great deal.
Re: Preventing cap walk [Re: DGS] #2602690
01/07/19 12:24 AM
01/07/19 12:24 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Aluminum caps don't prevent cap walk. (not saying they aren't a good replacement for cast iron) Aluminum just doesn't allow the transfer of material at the mating surface, so there is no evidence of it. If you see peppering on the mating surfaces, you are running to much ignition advance at some point in your curve. Early timing tries to hammer the crank out of the bottom, lifting and distorting the caps. Delay the ignition and the crank rolls forward....
There is a whole lot more power potential in a factory big block than most think. Just have to treat it right.
Re: Preventing cap walk [Re: TRENDZ] #2602779
01/07/19 03:23 AM
01/07/19 03:23 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
My understanding:
Aluminum caps absorb the "shocks" so the caps shouldn't bounce around as much as iron/steel. Maybe it was Monte Smith who used the analogy of hitting something with a dead-blow hammer vs a standard hammer that doesn't absorb the hit.
Most girdles aren't expected to strengthen the block; the benefit is tying the main caps together to keep them better aligned as a unit when the rotating assembly is trying to push them all in different directions.
It's funny (to me) when there always seem to be people who p!ss on one approach or the other, since I see benefits to using them both together.
Re: Preventing cap walk [Re: BradH] #2602790
01/07/19 04:44 AM
01/07/19 04:44 AM
I look at teing the main studs together with the girdle as a bad thing due to the girdle trying to flex the studs, main caps and block as the firing order occurs work scope Not a good thing, huh work twocents
Good intentions, designing producing and selling the girdle systems, don't always produce good results shruggy
Re: Preventing cap walk [Re: DGS] #2602791
01/07/19 05:20 AM
01/07/19 05:20 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Maybe not always, but there are some good running stock block strokers out there 1/2 filled and chastised. Pretty damn reliable ones too!
Re: Preventing cap walk [Re: Cab_Burge] #2602792
01/07/19 05:23 AM
01/07/19 05:23 AM
Washington
madscientist Offline
Washington
I agree with this cab. Every time I used a girdle the main bearings looked bad and finally we came to the conclusion that the girdle was actually moving stuff around.
And, most of the time, especially with fairly agressive lobes, you can take a stud girdle off a Chevy and they will make more power. The motion of the valve is translating all its business to other valves that shouldn't be moving.
The valve job seemed to last longer and look better on freshen up.
Re: Preventing cap walk [Re: DGS] #2602793
01/07/19 05:27 AM
01/07/19 05:27 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Tell me again how a plate with 22 odd bolts in it is flexing a 300,000 psi stud?
Re: Preventing cap walk [Re: Jerry] #2602794
01/07/19 06:35 AM
01/07/19 06:35 AM
Graz, Austria
DGS Offline OP
DGS  Offline OP
Graz, Austria
That's another thought I had: drill out the bolt hole in the block and cap a bit so that a bushing/sleeve can be fitted over the studs that extends into the block and cap.
Thanks for all the replies! Not that I'm having cap walk or plan to build an 800hp engine wink My question was just out of curiosity from an engineering standpoint: if such a simple solution with roll pins could help if someone (not particularly me) is experiencing cap walk.
Re: Preventing cap walk [Re: DGS] #2602885
01/07/19 01:19 PM
01/07/19 01:19 PM
an8sec70cuda Offline
Cross bolting weakens a stock block and still doesn't stop them from "walking". I remember seeing pictures on here of a Megablock that had some bad cap walk issues.
I don't think dowel pins would do much. The caps bounce, not necessarily moving them back and forth.
Just my opinion...I'd use aluminum caps and stud it.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Preventing cap walk [Re: DGS] #2602904
01/07/19 01:47 PM
01/07/19 01:47 PM
gregsdart Offline
gregsdart  Offline
All you can do for a stock block deal is run a center weighted crank with light bob weight, use studs and aluminum caps on a bb. Look at the new Ford Coyote blocks to see what it takes to keep everything from moving around too much. And they START with a center weighted crank!
Page 1 of 3 1 2 3
