Re: Preventing cap walk
[Re: DGS]
#2602617
01/06/19 09:52 PM
01/06/19 09:52 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Turn the timing back. It’s cheaper and easier.
[Re: 65Fury440]
#2602619
01/06/19 09:58 PM
01/06/19 09:58 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I’m not sure how quick you want to go but sometimes we over think things. I’ve gone 8.60’s with 440 blocks and 9.70’s with 360 blocks with no bandaids. Did I have a little cap walk, sure I had some. If I wanted to do a quick stock block 440 again I would put main studs and aluminum caps on it and go racing. Save up your money and get a good block. I did.
[Re: TRENDZ]
#2602640
01/06/19 10:40 PM
01/06/19 10:40 PM
Posts: 10,558 Rittman Ohio
fourgearsavoy
Rittman Ohio
Turn the timing back. It’s cheaper and easier. ![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif) I keep mine at 34* so it doesn't detonate because that is what kills ANY engine ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif) Gus ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: DGS]
#2602648
01/06/19 10:58 PM
01/06/19 10:58 PM
Posts: 31,083 Oregon
AndyF
Just thinking out loud: could you prevent cap walk with roll pins drilled into the parting line between block and cap (parallel to cap bolts)? A man just needs to know his limitations........ In other words if the block you have isn't working for you then upgrade to a better block. If you are going to use a stock block in your project then stay within the limitations of the stock block. You should be able to build a very reliable 600 hp big block engine without having to mess with any bandaids. If you need more than that then either take your chances or step up.
[Re: jwb123]
#2602657
01/06/19 11:17 PM
01/06/19 11:17 PM
Posts: 43,317 Bend,OR USA
Cab_Burge
[Re: DGS]
#2602688
01/07/19 12:18 AM
01/07/19 12:18 AM
Posts: 11,739 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Early 360, over 500HP, block filler, under 12:1, good gas, 38 degrees, ARP studs, and they stilled showed fretting. RPM plays into this a great deal.
[Re: DGS]
#2602690
01/07/19 12:24 AM
01/07/19 12:24 AM
TRENDZ
Milwaukee WI
Aluminum caps don't prevent cap walk. (not saying they aren't a good replacement for cast iron) Aluminum just doesn't allow the transfer of material at the mating surface, so there is no evidence of it. If you see peppering on the mating surfaces, you are running to much ignition advance at some point in your curve. Early timing tries to hammer the crank out of the bottom, lifting and distorting the caps. Delay the ignition and the crank rolls forward.... There is a whole lot more power potential in a factory big block than most think. Just have to treat it right.
[Re: Cab_Burge]
#2602792
01/07/19 05:23 AM
01/07/19 05:23 AM
Posts: 4,457 Washington
madscientist
Washington
I agree with this cab. Every time I used a girdle the main bearings looked bad and finally we came to the conclusion that the girdle was actually moving stuff around. And, most of the time, especially with fairly agressive lobes, you can take a stud girdle off a Chevy and they will make more power. The motion of the valve is translating all its business to other valves that shouldn't be moving. The valve job seemed to last longer and look better on freshen up.
[Re: Jerry]
#2602794
01/07/19 06:35 AM
01/07/19 06:35 AM
Posts: 640 Graz, Austria
DGS
Graz, Austria
I've even see some guys put bushings around the main studs to help prevent cap walk. it helps some, aluminum main caps on a big block are your number one add on that give you your best bang for your buck. cross bolt caps weaken the block because you have to remove the main webbing that's holding block together. That's another thought I had: drill out the bolt hole in the block and cap a bit so that a bushing/sleeve can be fitted over the studs that extends into the block and cap. Thanks for all the replies! Not that I'm having cap walk or plan to build an 800hp engine ![wink wink](/ubbthreads/images/graemlins/custom/wink.gif) My question was just out of curiosity from an engineering standpoint: if such a simple solution with roll pins could help if someone (not particularly me) is experiencing cap walk.
[Re: DGS]
#2602885
01/07/19 01:19 PM
01/07/19 01:19 PM
Posts: 13,404 Marion, South Carolina [><]
an8sec70cuda
Cross bolting weakens a stock block and still doesn't stop them from "walking". I remember seeing pictures on here of a Megablock that had some bad cap walk issues.
I don't think dowel pins would do much. The caps bounce, not necessarily moving them back and forth.
Just my opinion...I'd use aluminum caps and stud it.
[Re: DGS]
#2602904
01/07/19 01:47 PM
01/07/19 01:47 PM
Posts: 10,021 Frostbitefalls MN (Rocky&Bullw...
gregsdart
All you can do for a stock block deal is run a center weighted crank with light bob weight, use studs and aluminum caps on a bb. Look at the new Ford Coyote blocks to see what it takes to keep everything from moving around too much. And they START with a center weighted crank!
