Who sells the correct OE style oil pan drain plugs #2600355
01/02/19 11:24 AM
01/02/19 11:24 AM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
Anyone know who sells the correct OE style oil drain plugs? Specifically for a small block.
Re: Who sells the correct OE style oil pan drain plugs [Re: vinnyd76] #2602737
01/07/19 01:49 AM
01/07/19 01:49 AM
Martinsville, IN
cdwmotorsports Offline
Martinsville, IN
440source has some in their stock parts section, I hunk they were used but reconditioned
eBay-cdwmotorsports
Re: Who sells the correct OE style oil pan drain plugs [Re: vinnyd76] #2602744
01/07/19 02:03 AM
01/07/19 02:03 AM
SoMd, USA
135sohc Offline
135sohc  Offline
SoMd, USA
I am not sure what correct OE is but awhile back I figured out my former B-van (318) had the same thread pitch used on my Shadow (2.2). The drain plug on the Shadow is still the original at almost 25 years old and it does not drip a drop at all. Took care of the drip the van always had.
Looks like 440 source is selling the auveco sourced plug. It runs about half the OEM one but looks identical.
http://store.440source.com/Drain-Plug-Factory-Style/productinfo/109-1522/
Re: Who sells the correct OE style oil pan drain plugs [Re: vinnyd76] #2602756
01/07/19 02:30 AM
01/07/19 02:30 AM
Martinsville, IN
Martinsville, IN
This is the one I was speaking of...
http://store.440source.com/Oil-Drain-Plug-Original-Used-Factory/productinfo/100%2D1517/
eBay-cdwmotorsports
Re: Who sells the correct OE style oil pan drain plugs [Re: vinnyd76] #2602778
01/07/19 03:23 AM
01/07/19 03:23 AM
AndyF Online content
AndyF  Online Content
Do you want factory correct as of 1970 or something modern that works better? You can buy new oil drain plugs from a Dodge dealer for the Dodge Ram or something like that. It is a nice heavy duty bolt with a large rubber type washer. The new ones are OE correct but not OE correct for 1968.
Re: Who sells the correct OE style oil pan drain plugs [Re: vinnyd76] #2602805
01/07/19 09:29 AM
01/07/19 09:29 AM
MA
steve70 Offline
steve70  Offline
MA
1970 Challenger T/A 4 speed
Re: Who sells the correct OE style oil pan drain plugs [Re: AndyF] #2602900
01/07/19 01:41 PM
01/07/19 01:41 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Mopar OEM part number 06035417
1/2-20 thread.
Rich H.
Esse Quam Videri
Re: Who sells the correct OE style oil pan drain plugs [Re: vinnyd76] #2603190
01/07/19 11:57 PM
01/07/19 11:57 PM
Oh
P
parksr5 Offline
parksr5  Offline
P
Oh
