Rear Disc Conversion #2601195
01/03/19 11:05 PM
01/03/19 11:05 PM
Near Columbus, Ohio
++MAX WEDGE++ Offline OP
Near Columbus, Ohio
I have a 8 3/4 rear under a 78 Dodge D150, short bed, step side, regular 15" rim will be used. It currently has drum set-up on it and I would like to use a disc conversion. What disc conversion product would you recommend? Is there one that is better than the other? Thanks in advance.
Re: Rear Disc Conversion [Re: ++MAX WEDGE++] #2601227
01/04/19 12:09 AM
01/04/19 12:09 AM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
https://www.forabodiesonly.com/mopar/thr...ch-axle.422090/
I've got this, for your consideration.
Thank's
Jim V.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Rear Disc Conversion [Re: ++MAX WEDGE++] #2601488
01/04/19 02:46 PM
01/04/19 02:46 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
There are kits on ebay for $350 on up depending on your budget. One thing to look at is your axel bearings if you can use adjustable or nonadjustable with the kit.
Re: Rear Disc Conversion [Re: ++MAX WEDGE++] #2601715
01/04/19 10:38 PM
01/04/19 10:38 PM
Near Columbus, Ohio
Near Columbus, Ohio
Thank you for the help. I currently have stock bearing in it now and I don't think I want the entry level disc set-up. Photo of rear to get a little more idea. Very open to more thoughts.
Re: Rear Disc Conversion [Re: ++MAX WEDGE++] #2601971
01/05/19 05:26 PM
01/05/19 05:26 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
Mopar Action and Ehrenberg just ran an article about doing 8 3/4 disc brake conversion on the cheap using Jeep Liberty parts.
Re: Rear Disc Conversion [Re: ++MAX WEDGE++] #2602340
01/06/19 06:26 AM
01/06/19 06:26 AM
Guitar Jones Online laugh2
Looks like a race truck. Why not just use a Wilwood kit or similar?
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: Rear Disc Conversion [Re: ++MAX WEDGE++] #2602481
01/06/19 04:38 PM
01/06/19 04:38 PM
Near Columbus, Ohio
Near Columbus, Ohio
I didn't realize how many kits were out there as well as options for them. Has anybody on here personally have these on their car/truck that has any pro's or cons on any kit they use?
up Thank you every body for the much need help and advise.
Re: Rear Disc Conversion [Re: ++MAX WEDGE++] #2602764
01/07/19 02:51 AM
01/07/19 02:51 AM
I used a Wildwood kit on my Duster and later on the Scamp. Never a problem in over 20 years with it.
