Mini-tubs....?? #260087
03/20/09 04:18 PM
03/20/09 04:18 PM
Camp LeJeune, NC
USMCBuckWild Offline OP
Camp LeJeune, NC
I have a 74 Duster with stock location springs and factory sheetmetal. What do i have to do to mini-tub it? I believe I need 2 1/4 inches on each side. I know I have to move the springs as well, but i know how to do that. Any company that makes a tub or tub-kit that is a basic drop in for dummies like me?
THANKS!!
Re: Mini-tubs....?? [Re: USMCBuckWild] #260088
03/20/09 06:43 PM
03/20/09 06:43 PM
Elbridge, NY
Dart1031 Offline
Dart1031  Offline
Elbridge, NY
You don't need no stinkin' kit. Just cut the stock wheel well down the middle and move it over to the frame rail. Add a strip of metal in between them and you're done.
You'll need to cut the bottom of the trunk hinge bracket off for clearance, then re-weld it to the inner tub once it's moved in. Sorry I don't have any pics of it, but I've had two cars done this way.
Re: Mini-tubs....?? [Re: Dart1031] #260089
03/20/09 06:47 PM
03/20/09 06:47 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
how much clearens do you gain by mini tubbing and not moving in the springs
1.39 9.85 - 137 mph
Re: Mini-tubs....?? [Re: USMCBuckWild] #260090
03/20/09 07:42 PM
03/20/09 07:42 PM
Newfoundland
codfish Offline
codfish  Offline
Newfoundland
Here's everything you need and then some. A weekend and some and you'll be good to go. Mine turned out good.
I relocated my springs to the inside of the frame rails, keeping the outside "wall" of the frame intact.
http://www.bigblockdart.com/techpages/wells.shtml
codfish
Re: Mini-tubs....?? [Re: codfish] #260091
03/20/09 11:37 PM
03/20/09 11:37 PM
Salisbury North Carolina
8secDart Offline
8secDart  Offline
Or you can just bring it to me.If you don't heve the right tools it's a pain in the butt.Lenny
Re: Mini-tubs....?? [Re: 8secDart] #260092
03/20/09 11:48 PM
03/20/09 11:48 PM
Camp LeJeune, NC
Camp LeJeune, NC
Well I appreciate all the help gentlemen. I am looking forward to attempting to do this properly. The car is at my uncle's body shop in Connecticut, and it's spread out all over the shop in the painting process. Hopefully, it's as easy as it looks and we can squirt the trunk and start slapping the little junk back together. Thanks again!
It ain't illegal unless you get caught!
Re: Mini-tubs....?? [Re: USMCBuckWild] #260093
03/21/09 12:26 AM
03/21/09 12:26 AM
Kentucky
Hillbillyracer Offline
mopar addict
mopar addict
Kentucky
If you don't move the springs in I don't think you will gain anything by mini-tubing it.On my dart the tire is about as close to the spring as it is to the wheeltub
1972 Dodge dart,,1964 Plymouth Valiant station wagon,1976 Dodge M880 truck,1995 Dodge 3500 rollback
