W9 Ritter Small Block #2600536
01/02/19 05:36 PM
01/02/19 05:36 PM
Carson City, Nevada
Biginchmopar Offline OP
Carson City, Nevada
Somebody said I needed do an update of the W9 Ritter Small Block. Here are some pics:
Re: W9 Ritter Small Block [Re: Biginchmopar] #2600539
01/02/19 05:40 PM
01/02/19 05:40 PM
Carson City, Nevada
Carson City, Nevada
Couple more pics:
Re: W9 Ritter Small Block [Re: Biginchmopar] #2600540
01/02/19 05:41 PM
01/02/19 05:41 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Somewhat still on topic... anybody else notice that Ritter posted a bunch of block stuff in the race parts for sale forum here recently? I'm not a SBM guy, but it's still interesting to see it.
EDIT: Them's some mighty shiny crankshaft throws you got there, Mister. scope
Re: W9 Ritter Small Block [Re: Biginchmopar] #2600543
01/02/19 05:47 PM
01/02/19 05:47 PM
Carson City, Nevada
Carson City, Nevada
I'm waiting on an Oil Pan from Dan Olsen and an a few other items. I'll probably put the heads on this upcoming weekend.
Re: W9 Ritter Small Block [Re: BradH] #2600545
01/02/19 05:48 PM
01/02/19 05:48 PM
Carson City, Nevada
Carson City, Nevada
Bryant Crankshaft up
Re: W9 Ritter Small Block [Re: Biginchmopar] #2600550
01/02/19 06:08 PM
01/02/19 06:08 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Thanks for the updates, keep us posted.
Re: W9 Ritter Small Block [Re: Biginchmopar] #2600562
01/02/19 06:42 PM
01/02/19 06:42 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
It's a shame to cover up those beautiful parts with an oil pan!
Re: W9 Ritter Small Block [Re: Biginchmopar] #2600574
01/02/19 07:18 PM
01/02/19 07:18 PM
Washington
madscientist Offline
Washington
Can't wait to see what this thing does on the pump. What do you have for an induction system? Hoping that Ritter finally gets his blocks out there so maybe, just maybe the price will come down a bit.
I think I can speak for most of us when we say we love updates!!!
Re: W9 Ritter Small Block [Re: Biginchmopar] #2600591
01/02/19 07:51 PM
01/02/19 07:51 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
Thanks for the pics ! Mines back from QMP waiting on me. (I've been busy working on my Duster's indy motor.)
I noticed you had to grind a fair amount for the rod clearance,did you also have to grind for the crank throw clearance ?
Who's lifters are you using ?
I'm sure you posted it earlier but how big is it ?
Re: W9 Ritter Small Block [Re: DavidDean] #2600605
01/02/19 08:20 PM
01/02/19 08:20 PM
Carson City, Nevada
Carson City, Nevada
I did grid a bit of rod clearance but I'm using BME 500 Rods (Pretty Big).
The only place the cranksahft did rub a little was on the front counter weight was not chamfered like the rear. It is a little spot were the machine work on the ritter block doesn't go down deep enough, no big deal just a few second with a die grinder and whala!
4.100" Stroke x 4.185" Bore 451CID
Erson Lifters (.904")
Re: W9 Ritter Small Block [Re: Biginchmopar] #2600700
01/02/19 11:20 PM
01/02/19 11:20 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
man stuff looks amazing great job I'm bettin it makes.. your car fly
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: W9 Ritter Small Block [Re: Biginchmopar] #2600772
01/03/19 01:51 AM
01/03/19 01:51 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
get that thing screwed together and make some noise Rob! Can’t wait to see it go!!
Re: W9 Ritter Small Block [Re: J_BODY] #2600837
01/03/19 10:37 AM
01/03/19 10:37 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Nice stuff!
Re: W9 Ritter Small Block [Re: Biginchmopar] #2600893
01/03/19 01:02 PM
01/03/19 01:02 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Are there any oil drain back holes in the rear of the valley?
Re: W9 Ritter Small Block [Re: fast68plymouth] #2601104
01/03/19 08:01 PM
01/03/19 08:01 PM
Carson City, Nevada
Carson City, Nevada
Yes
Two actually, I won't have an oil pump/distributor drive in this engine so it will have an extra. beer
Re: W9 Ritter Small Block [Re: Biginchmopar] #2601108
01/03/19 08:08 PM
01/03/19 08:08 PM
Carson City, Nevada
Carson City, Nevada
This is the rear oil return, I opened this up a little and smoothed the opening.
Re: W9 Ritter Small Block [Re: Biginchmopar] #2601112
01/03/19 08:15 PM
01/03/19 08:15 PM
Carson City, Nevada
Carson City, Nevada
Front oil return
Re: W9 Ritter Small Block [Re: Biginchmopar] #2601117
01/03/19 08:24 PM
01/03/19 08:24 PM
Carson City, Nevada
Carson City, Nevada
I don't have a picture of the other oil return in the back but it is right below the oil pump drive gear location. Both return to the rear pan rail next to the rear main cap. See picture #3 in at the beginning of this post.
Re: W9 Ritter Small Block [Re: Biginchmopar] #2601129
01/03/19 08:45 PM
01/03/19 08:45 PM
Renton Washington
Triple Threat Offline
Renton Washington
What was the overall quality of the block, and how much work was required to get you to where you are now?
Bore and hone?
Mainline need honed?
Lifter bores honed?
Any other clearance or areas of concern?
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: W9 Ritter Small Block [Re: Triple Threat] #2601151
01/03/19 09:32 PM
01/03/19 09:32 PM
Washington
Washington
Bore and hone?
Lifter bores honed?
Everything you mentioned should come undersized. Maybe rough bored but not honed. How do I know how the cylinder was finished? Or what size the main bores need to be? Or even lifter sizing.
It's part of building an engine that all those things and more need to be left undersize or too many times you end up doing more work.
