Dana 60 gear oil capacity. #2596013
12/23/18 11:01 PM
12/23/18 11:01 PM
Mt. Vernon, Ohio
dartman366 Offline OP
Mt. Vernon, Ohio
just pulled the aluminum LPW cover off my d-60 to check things over and cannot remember how much oil I need to put back in ,this cover has no sight plug for the correct level just a drain plug and a fill plug up at the top, I have 2 1/2 quart in it so far, how much are you drag racers running in your's?
Re: Dana 60 gear oil capacity. [Re: dartman366] #2596043
12/23/18 11:45 PM
12/23/18 11:45 PM
Cedar Lake,IN
d330 Offline
d330  Offline
Cedar Lake,IN
1 and 3/4 here..with a plain steel cover
Re: Dana 60 gear oil capacity. [Re: dartman366] #2596050
12/23/18 11:57 PM
12/23/18 11:57 PM
AndyF Offline
AndyF  Offline
3 qts with the LPW cover.
Re: Dana 60 gear oil capacity. [Re: dartman366] #2596063
12/24/18 12:29 AM
12/24/18 12:29 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Drag only? 2 quarts, if that.
Re: Dana 60 gear oil capacity. [Re: CMcAllister] #2596127
12/24/18 02:33 AM
12/24/18 02:33 AM
The Mopar engineers that use to put on the drag seminars always recommended 1 quart gear oil max in both Dana 60 and 8 3/4 as already stated, that was for a drag only car.
I would run around 2 quarts on a street car just to be safe twocents
Re: Dana 60 gear oil capacity. [Re: Cab_Burge] #2596198
12/24/18 11:21 AM
12/24/18 11:21 AM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
ok guy's 2.5 quarts should hit the happy median then, thank's to all,, PS, the gears still look great after 14 plus years of abuse. up
Re: Dana 60 gear oil capacity. [Re: dartman366] #2596240
12/24/18 12:58 PM
12/24/18 12:58 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Mine has a LPW cover. There is a level plug on the right side. 3 qts was still below that plug. What I did notice running lower levels before is that very little lube was in the axle tube. Mine had a little surface rust on the axle shafts. So this time I upped it a little. Don't know if that will help. We'll see.
Doug
Re: Dana 60 gear oil capacity. [Re: dartman366] #2596283
12/24/18 01:57 PM
12/24/18 01:57 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
It really depends on the cover - a stock cover is usually about 2 1/4 to 2 1/2 quarts - some of those cast covers hold a little more
Re: Dana 60 gear oil capacity. [Re: DoubleD] #2596308
12/24/18 02:58 PM
12/24/18 02:58 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
This cover was bought as a Jeg's house brand, no level plug in it, maybe that is why it was less expensive than the LPW unit altho it had the Ultimate 60 cast into the center outer cast in bracing and bearing cap tensioner bolts, adding another 1/2 quart would not bother me.
Re: Dana 60 gear oil capacity. [Re: dartman366] #2596342
12/24/18 04:15 PM
12/24/18 04:15 PM
Downtown Roebuck Ont
Twostick Online content
Still wishing...
Twostick  Online Content
Still wishing...
Wasn't there a thread on here a while ago about most of those aluminum covers causing oiling issues compared to the stock cover?
Kevin
Re: Dana 60 gear oil capacity. [Re: Twostick] #2596359
12/24/18 04:53 PM
12/24/18 04:53 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
I think the consensus was they weren't that good for the street, by the looks of how mine is doing they seem to be ok for drag racing as mine has been on since I built the dana 14 years ago,,,same pro gears and bearings up
Re: Dana 60 gear oil capacity. [Re: dartman366] #2596367
12/24/18 05:12 PM
12/24/18 05:12 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I always put in 2 quarts in the dana 60
Re: Dana 60 gear oil capacity. [Re: dartman366] #2596378
12/24/18 05:31 PM
12/24/18 05:31 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Stock cover, two of these
Re: Dana 60 gear oil capacity. [Re: dartman366] #2596596
12/25/18 01:08 AM
12/25/18 01:08 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
The LPW cover has a shape conductive to fluid flow. However really no need for a braced cover on a street car. Fill the fluid to the bottom of the tube (less for drag only if you wish) and you'll be fine.
Doug
Re: Dana 60 gear oil capacity. [Re: dartman366] #2596814
12/25/18 05:09 PM
12/25/18 05:09 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Mopar factory spec is 2.75 quarts..
Just my $0.02.. wink
Re: Dana 60 gear oil capacity. [Re: Cab_Burge] #2596833
12/25/18 05:46 PM
12/25/18 05:46 PM
North Central, Indiana
Roughbird72 Offline
Roughbird72  Offline
Cab, wouldn't there also be a level difference between a spool and a suregrip? shruggy
72 Plymouth Roadrunner 11.08@123.25
Re: Dana 60 gear oil capacity. [Re: dartman366] #2600497
01/02/19 04:22 PM
01/02/19 04:22 PM
an8sec70cuda Offline
2 quarts in a street/strip in a Dana 60. No more needed.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Dana 60 gear oil capacity. [Re: Roughbird72] #2600508
01/02/19 04:34 PM
01/02/19 04:34 PM
They didn't recommend more or less with a spool or posi shruggy
Re: Dana 60 gear oil capacity. [Re: dartman366] #2600549
01/02/19 06:06 PM
01/02/19 06:06 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I have had an LPW cover on mu Camaro's dana since 2001, It is a street car that sees the racetrack once in awhile. Not one issue with the gearset or bearings at all.
Re: Dana 60 gear oil capacity. [Re: Cab_Burge] #2601182
01/03/19 10:44 PM
01/03/19 10:44 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
Because they had shelves full of spare parts and we're competing in stock/super stock. Gear life wasn't a priority.
Whatever the service manual says is what I follow. I've never lost a race because my rear end fluid was slowing me down.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
